Northampton Co Public Safety
Deespag
County was testing Ops 1 on the new system today. TGID is 10001 per the radio chatter.
Attached below is the audio.
I did hear that is 10001 listed on radio reference?
NCFA
Plainfield Township, Pa
Tac 2 TGID is 12102 it was operation today for a short bit. Audio confirmed it on my end. I assume Tac 1 will be 12101 and other Tac TGID going up from there.
Deespag
Yesterday I heard ID 10000 ? Did you notice that
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
As folks note more talkgroups coming online, please submit updates to the database using the submit option on the database page. Select MENU, then SUBMIT CHANGES. Limit changes to talkgroups you can identify based on use or over the air confirmation. Unknown talkgroups should be discussed in the forums and/or wiki.
NCFA
Will do.
NCFA
If any want to start adding the UID's to the system they made it pretty easy with Bethlehem Twp PD.
For PD 1754 the lookup is 1117054 so the 3,4,6,7 numbers are the Units number. All my audio corresponds with the UID. The attached docs are the UID's my scanner has been populating besides Bethlehem FD.
Deespag
URL isn’t working I think
Deespag
So these ids will come up in my scanner or do they need to be programmed?
NCFA
I very rarely hear anything out of Bethlehem anymore from Nazareth.
I'm switching over to a yagi as soon as the system is up and running. As of now, I do get them with the SDS 200 and a D130NJ roof mounted. It seems as though I'm pulling in only some of the transmissions but I'm not sitting here monitoring it back to back with the calls platform. Is Bethlehem going to going to be simulcasted on the new system?
