I have searched the FCC ULS database and programmed all of the Active license frequencies for NOVEC. Nothing heard. Anyone with info on where NOVEC operations may be heard?
That is probably not a voice frequency. Do you have a radio that can listen to DMR? If not, you are probably out of luck.All I have heard for two days is occasional telemetry bursts on 173.39625 (173.395 programmed into the radio)
-----------------------I have searched the FCC ULS database and programmed all of the Active license frequencies for NOVEC. Nothing heard. Anyone with info on where NOVEC operations may be heard?
I have the freqs for this license programmed into my 436 & 536 as conventional and trunked. I hear nothing either way. I haven't analyzed this system using DSD+.Here's the license for what I believe to be a MOTOTRBO IP Site Connect system:
https://www.radioreference.com/apps/db/?fccCallsign=WQKQ612
153.2000 has the characteristic long data bursts for IP Site Connect.
Dave
I've run the freqs of the system in DSD+. I get data decode every few minutes on each freq. Only info obtained is Color Code 1. No talkgroups/voice calls as of 24 hours worth of monitoring.I have the freqs for this license programmed into my 436 & 536 as conventional and trunked. I hear nothing either way. I haven't analyzed this system using DSD+.
Is this type of system able to be listened to?
