SDRTrunk Not hearing talkgroups
dave3825
Suffolk County NY
DSDPlus logs information about P25 systems in DSDPlus.P25data.
This file includes information on site channels and their usage (CC/SCC/voice/data).
I think we established a while back a freq or two that was not listed and believe the db is a little out of date. @AngWay can you post your DSDPlus P25 Data file?
AngWay
Curious
Buchanan, Va
RR no longer differentiates between primary and alternate designations. "c" is used to designate frequencies that are control channel capable. This includes both primary and secondary control channels. The database shows multiple control channel capable frequencies for all 3 of the Buchanan County sites.
FYI: DSDPlus logs information about P25 systems in DSDPlus.P25data. This file includes information on site channels and their usage (CC/SCC/voice/data). CC is a frequency used as a control channel. SCC is a secondary control channel. This information also shown in SDRTrunk in the Details tab. You can use this information to confirm the accuracy of the RR database.
I'm trying to research trunk recorder but i can't find the answer to the question does it just record or does it also track p25. like sdrtrunk can i use trunk recorder to listen ? Thanks
RMason
Mississippi / Colorado
Many use Trunking Recorder to record audio from SDRTrunk. Setup is relatively straightforward.
“Trunking Recorder is a Windows application for recording/importing audio from trunked radio systems monitored by Unitrunker, SDRTrunk or ProScan. Trunking Recorder will save all the recorded calls and allows searching and playback through a web browser. Trunking Recorder will also queue up recorded calls so you never miss any activity when multiple talkgroups are active at the same time”
Trunk Recorder (similar name, but different application) is Linux based.
Trunk Recorder is able to record the calls on trunked and conventional radio systems. It uses 1 or more Software Defined Radios (SDRs) to do this.
AngWay
Curious
Buchanan, Va
I have tried searching for this but can't find nothing. i just got my j pole up higher another 10 feet i guess and i got the LNA and FM Filter at the antenna. i was going through the spectrum and i came across this at 548.249 and it's a guy preaching it's on narrow band but why is it that high up in the freqs? it's weird i can hear it as clear as day on narrow and wideband FM
RMason
548.250 is likely a wireless microphone. Are there any churches nearby?
