keithmj
- Joined
- Dec 19, 2002
- Messages
- 304
- Reaction score
- 2
I noticed that others have had this problem and now I have it. I downloaded the database from RR like I usually do, I was updating everything. The frequencies and talk groups are in the scanner, I uploaded and downloaded to check. The scanner reboots and flashes the numbers1-10 but the screen says the "Nothing enabled" I push scan and nothing happens and push the numbers nothing happens.
I then took a file I saved before I updated and uploaded it into the scanner and the scanner scans? Does anyone have any ideas as to why this would do this? It has to be something simple.
So I repeated everything and now it won't even scan with the file I uploaded that was working? Any ideas? I am using ARC500PRO and 20-047 cable.
Thanks.
PRO-197 scanner
Thanks.
PRO-197 scanner
