Since I began scanning the new P25 system here in Las Vegas, I've noticed that the audio quality on transmissions is all over the place. NHP field units usually sound alright, however NHP dispatch more often than not comes in extremely loud and overblown, almost sounding like the speakers are clipping. Nevada DOT is probably the worst, almost all traffic is so overblown or overdriven I often cannot even make out what's being said.
Anyone else having the same results? Any suggestions?
So far:
I've resorted to adding a volume offset to the main channels I listen to, but that just makes it alright for some transmissions, but hard to hear the quiet stuff.
I've got almost full signal strength on simulcast, and using the built in attenuator has no effect.
I've tried all the onboard filters with zero changes.
Plugged into a high quality speaker system the results are slightly more tolerable to listen to, however the problem persists.
When I go mobile with the SDS100 all over the city the results are exactly the same.
I mostly scan SNACC P25 and that system has always sounded fantastic out of the box.
So far:
