NWORPSS Site and Talkgroup Discussion
Sting11
Sylvania, OH
Sounds more like LMHA security. Listen to the call logs from a couple days ago. I’m a retired TARTA bus driver. Doesn’t sound like TARTA.
I'll trust your expertise on that for sure - I was just matching with the radio IDs, only heard a couple of snippets on the talk group.
GILLIG40
Northwest, Ohio
They were talking about an incident on the 8th floor of the Ten Eyck Tower and mentioned LMHA.
2001scoop
Toledo, OH
Lucas county / Toledo fire and rescue question: WTH is Medic 26 ?
25 Stations in Toledo Fire and Rescue..
Did they stick a transport medic at Station #1, #6, or at the former Ottawa Hills Fire Station which once housed Rescue 15? Where, what is Medic 26, and what's going on with Station 12 that was closed, re-built and then re-opened? On PulsePoint surprised if even one run a day for E12 ?
It’s what used to be LS5. It’s running out of 25’s and will be sent to 14’s eventually once they add-on. It also alternates taking calls vs M25.
GILLIG40
Northwest, Ohio
Toledo PulsePoint is back up again. If you hit the speaker icon in the upper right corner you can now hear fire department comms. Thanks again to the Toledo Firefighters Local 92
KQA726
I noticed PulsePoint was back- thank you Local 92. But...when I hit the speaker icon it says: "Dispatch audio not provided by LCEMS" and there is no audio? I am using v4.22. Do I need a different version?
GILLIG40
Northwest, Ohio
The new listing is L92 Toledo Firefighters Local 92. The version that I’m using is v4.22 (4664) . Ipad iOS 18.1.1
Diesel0001
Northwest Ohio
Not sure if this is the correct spot for this. But I have an Unication G5 dual band pager. I am trying to listen to Springfield Twp Fire Dept on the Northwest Ohio Regional Public Safety System, but hear nothing on those talkgroups. I've programmed the talk groups in unified fire along with ops14 talk group but not hearing anything. I'm hoping someone is familure with Unication and G series pagers that can help. Unication has a built in Import tool for RR from where I got my channels/talkgroups from. Any help would be amazing!
GILLIG40
Northwest, Ohio
Springfield TWP fire is heard on unified fire. Are you hearing anything on unified fire. Springfield TWP fire station numbers are listed below.
I’ve monitored OPS14 in the past. I never heard anything. A lot of what is listed for NWORPSS is not used.
Diesel0001
Northwest Ohio
Lucas County EMS dispatches Springfield Twp/Monclova/Whitehouse/Waterville/Maumme on Disp1 under unified Fire Departments. Took me a while to figure it out. Now, my new challenge is to try to find a way to isolate those 5 departments down so I don't have to hear all of Lucas County FD being dispatched...its annoying.
Diesel0001
Northwest Ohio
It works for me. See if you need an update for the app.
Diesel0001
Northwest Ohio
Anyone know why Springfield twp fire paging tg is not listed on RR import to PPS is not listed. There is one, but it shows no TG. Maumee and Monclova are there and work. I want to isolate the rest of the county to those 3 dept so I don't have to hear all of Lucas County.
wa8pyr
Staff member
Lead Database Admin
Ohio
No one has identified and submitted it yet.
Sting11
Sylvania, OH
As far as I can tell, paging talkgroups for Toledo, Sylvania Twp, and Springfield Twp don't exist. By the numbering convention of the other paging talkgroups, Springfield *should* be 9951, 9952, 9953, and 9956...but I run ID search on NWORPSS and have never received anything of the sort. I wonder if those departments use a different means of paging?
ctpd845
Martin, Ohio
I don't want to sound like a jerk, but this has been explained to you already. There is no way to isolate Springfield Twp. Fire, they do not have a paging talkgorup, this is only for the departments in the county that still have volunteers. Also, there is no such thing as Lucas County EMS, that department was disbanded last year. The consolidated dispatch for police and fire is run by the Lucas County through a Regional Council of Governments.
Sting11
Sylvania, OH
Heard a short transmission on TGID 60072 this evening. It's in the law enforcement numbering sequence, and sounded like a direct/tac channel. I didn't catch the unit IDs. Will keep monitoring for it.
Diesel0001
Northwest Ohio
I don't know. It's weird. Maumee and Monclova show up with their paging frequencies and those work and I have them on a seperate knob but yea Springfield is not listed at all. Not sure.
Diesel0001
Northwest Ohio
I wasn't asking about it again, I was simply making a statement. I mean Maumee, Monclova are listed in the DB and they're paging channels work and they are dispatched by Lucas County also.
Sting11
Sylvania, OH
Now that it's been explained that the paging talkgroups are only for the fire departments with a volunteer contingent, it makes perfect sense.
Sting11
Sylvania, OH
Same situation as I posted sometime last year: 60072, 4898xxx radio IDs. It was thought then it might be LMH Public Safety, and I haven't heard anything on it yet to dispute that notion.
