NX-700-K Toasty! Burnt circuit board...
westcoaster
Not sure if the power was hooked up backward or whether the radio was struck by lightning.
Either way it smells crispy in there.
Is this fixable? What components do I need?
Is it a multi layer board?
This is for an NX700-K
kd4efm
EL98 Florida
YUP, burnt.
Board replacement for sure or get a nx5700 OR NX-3720.
NX-700 EOL
ramal121
Lots and lots of watts
Calif Whine Country
That's the protection diode. Power hooked up bass ackwards without a fuse? Clean it up, remove the diode and slight chance that a well placed jumper might restore power to the board. But by the looks of the moon crater I wouldn't hold out too much hope.
westcoaster
I can smell that photo.
LOL
Yes, it has a distinct smell that anyone who has inadvertently let out the magic smoke knows all too well....
It was a gamble and I lost... Win some, lose some.... Although, it is providing some entertainment....
looks like L401, L402, and L403 vaporized (403 was barely hanging on and fell off with a touch of a screw driver....)
westcoaster
Well, the back side of the board survived....
What is L401, L402, L403?
D405 and C103? I can't read that last one.... Beside 401...
Thanks,
Reference Number Part Number Description
L402,403 L92-0179-05 CHIP FERRITE "Surge Absorption"
D405 DSA3A1 DIODE "Reverse Protection"
C103 CK73HB1E103K CHIP C 0.010UF K
I can't find a reference for L401, so maybe a space on the board, but not installed? CN401 is the B+ connector, is that what you are seeing?
westcoaster
No, It is L401 on the schematic above CN401 is off to the far right in IMG_6747
Looking at it, L401 may not have been installed. It may have simply been a couple pads on the circuit board.
At least nothing cratered underneath....
Looking at the way the traces have lifted, this is going to need some pretty creative redneck engineering if this thing ever wants to see life again....
AM909
Radio/computer geek
SoCal
Is F401 good (and hasn't been replaced)? If so, the damage may be confined to the crispy area. If it's blown, you'll have other bad stuff to deal with or, better, not.
AM909
Radio/computer geek
SoCal
The PA brick Vdd (IC102 pin 3) is also fed from unswitched B+ via ferrite chips L107, L108, and L109.
westcoaster
F401 does not appear damaged. Is it possible to replace the ferrite chips with jumper wire to see if the radio simply turns on?
The protection diode can be replaced with a jumper, just wondering about the chips...
Thanks,
AM909
Radio/computer geek
SoCal
Chip inductors can be replaced by jumpers for testing, yes.
You don't want to replace the D404 varistor or D405 diode with a jumper unless you want to see more flames. :)
n0fwg
Minnesota
We had a bus fleet mechanic do the 24Volt jump start trick on several school bus's ONCE... That reverse protection diode is actually zener diode. Resulted in burned boards in the same area and PA audio amp etc.. His manager was not amused
tlemke940
Lyons, OR
Just to compare to a intact radio
