hey upman has Uniden got a portal for the purchase of upgrade keys form outside the USA yet?
He posted the solution previously: Go through a USA dealer.
In my case it's both the ICE and Comtronics Con+ systems. I only have one Cap+ system programmed in my x36HP scanners and it's not busy.
Has anyone noticed a return of the MotoTrbo wrong Talk Group problem after the NXDN upgrade?
Is there going to be a fix for the conventional recording of Fed comm freqs where the encrypted comms will be skipped like in the previous software version? I had 162 comms with about 10% unencrypted comms yesterday; but had to see all the muted encrypted comms pass by while doing the playback. It's definitely frustrating when we were used to just having the 436 record the unencrypted comms in the previous version.
It would be nice if muting encryption was an option that a user could set on a per system basis. Some folks (I for one) would like to be able to at least log TG's & RID's when researching a system for the purpose of determining & submitting to RR. If everything is encrypted then there is no research that can be performed. Effectively turning a $500 tool into a paper weight is BS Uniden.
(If Whistler can do it! nuff said..)![]()
Changed operations for encrypted audio, Scan is skipped, Search stays, and Trunked Discovery logs ENCRYPTED
Mine also went through at $30, last night (and $60 for DMR)I just checked MY NXDN went through at $30.00 and MY DMR went through at $60.00 yesterday morning.
Did anyone see there card says 60 dollars pending ? for the NXDN Key update ? that is 30 dollars?
Why is the NXDN $60.00 it should be $30.00 anyone know whom to contact about this ???
You missed the introductory offer. $30 was half price before Sentinel support was added. Which actually happened over a week ago.
Thanks guys I got all 3 ProVoice $49.99 DMR $60.00 and NXDN $60.00 all pending on my card????
Weirdly, if you are also in Vernon NJ it appears to have gone through not at $30 (or $60) but $44.99. I forwarded to our IT group to have this reviewed and fixed. The price is still $30. NXDN will probably show up in the master database on Monday, but I'm going to let it continue at $30 for a bit to ensure that the export/import worked correctly.
