NXDN Upgrade for BCD436HP and BCD536HP Now Available!
Voyager
Just saw my first Private Call...shows up like all other Private Calls. I was in ID Search mode, so I suspect if I put it in ID Scan mode I'll need to enter a talk group if I want to see them? i0?
I can't say enough good things about this upgrade. Blows Whistler's NXDN (won't mention MotoTRBO) monitoring away! Hearing two-sided conversations, LCN analyzer is working well...well worth the $30 per scanner (3 of them).
Correct on the i0.
In fairness, it's not that Whistler's NXDN is bad. It's that they don't trunk NXDN. Within the limitation of what it does, it works.
This is the same as the criticism of previous models not working as well as they could on LSM systems. They weren't designed to decode LSM properly, and never claimed to do that. Likewise, the Whistler was never designed to trunk DMR or NXDN, and they never claimed to do that. They COULD (unlike LSM), but they don't. That was a choice they made to keep the cost down.
The improvement you hear is the result of actually following the trunk system as opposed to scanning it conventionally. Yes, you hear the replies better actually trunking the system since you don't have to hunt for the next active voice frequency.
Voyager
I thought I heard that it was announced for the overseas units.
Regardless, Uniden America (UPMan) does not sell in European markets. Not sure who does, but that's who you would need to contact.
Fidgety9996
Europe
This update is a big disappointment. It does not seem to show IDs on "encrypted" calls. It could easily decode them as AOR DV1 does.
NXDN4800 seems not to work at all when it is on frequency you cannot input into uniden. Uniden has 5 places after the dot for frequency - you need 6 in many cases.
Maybe that is also/or only the problem of the NXDN Very Narrow systems.
Great disappointment for 30 bucks.
I will have access to some kenwood hardware will perform some tests.
Dan_M
Erie County NY
Paul,
Thanks for Uniden sending out the new NXDN Firmware Version! Do We need to wait till Monday for the RR database update for NXDN? Or can Uniden push an update so we can use radio reference to update our scanners,
mule1075
Washington Pennsylvania
Paul,
You have to program NXDN manually for now. Sentinel support is not available yet. Hence the 30 dollar price. As soon as support for Sentinel is available the price goes to 60 dollars.
phask
zanesville
There will be (at some still un-released time a new Sentinel release), some changes required to implement NXDN, so NO, not next Monday.
Paraphrasing Paul above, but it's neem mentioned several times.
K2KOH
Silent Key
Putnam County, NY
So it seems I was right...the release of NXDN from Uniden was because they wanted the scanners to properly trunktrack, and they wanted to get it right. I guess good things truly do come to those who wait. I don't have any real NXDN where I am just yet...but I have a feeling Metro North will be doing some NXDN down the road. 90 bucks to upgrade all three radios was a bargain indeed.
Drumbum
Lynchburg Va
That means the upgrade price,for the SDS-100 will be 60 plus the DMR price over the $699 asking, hmmm
Sent from my VS995 using Tapatalk
garys
Texas
I am not seeing OTA aliases on the system I am monitoring. At least not on the 436HP I'm using. On the DSD+ set up a few feet away, I am seeing the aliases. Which I take to mean that the Uniden implementation doesn't process that yet.
Show me the post where someone said they are receiving the OTA aliases. Otherwise, go away.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Same with me - thanks for the confirmation.
I'd say it's a pretty minor thing to gripe about considering we got "full" (with trunking) support otherwise.
Still, it'd be nice to implement at a later date. I guess we'll see what comes...
garys
Texas
I'm pretty happy with it so far. The only other odd thing I've seen is that sometimes the scanner will stop on a TG, but there is no audio. Meanwhile, the audio can be heard on DSD+.
I seem to remember that there was something similar with Motorola trunking way back. I forget the details, but the scanner wouldn't process audio if it stopped on a TG midway through a conversation. From watching the display, I also note that when this happens, there is no UID displayed on the scanner, just the TGID.
If I get time later today, I'll manually program in a different NXDN system and see how that one plays.
Definitely worth the money.
captainmax1
Florida Keys
I'm glad to manually program a few local NXDN just to have the opportunity to enjoy this new upgrade. Will be glad when Sentinel or ARC536 gets updated as I hate manual labor. Next Monday would be great.
Jay911
That's known as "late entry". I haven't had enough time to explore if my radio is joining conversations on late entry properly or not.
