Ongoing Changes: Marion Co. MECA System
jerk
jerkville
kareem2o said:
Does anyone know if the xts 5000 can be used as a scanner?
Yes, and mostly no. If you are not an authorized user on the system it is difficult and you risk your radio being turned into a doorstop. Plus it only scans like 10-15 channels.
Buy a scanner, cheaper, easier to program, and scans more channels.
AL
kareem2o
ya I understand. I have the pro96 scanner and I also have a motorola stx 821 I like the stx better than I do my radio shack pro96 I've carried my stx so long I forgot it was just a scanner and now the IMPD has switch over to to new xts5000 I was just wondering if I could enjoy my hobby with the xts5000 and move on with my life?
jerk
jerkville
No! Do a search on RR or Google XTS5000 and scanner. You'll get your answer.
kareem2o
Ya, I've read plenty about google and moto and the RSS stuff. touchy subject.
A
Agentblack
Guest
maybe im dense or i missed it, but if your not a user on the system, and you set your radio to monitor their channels.. how would that make your xts a door stop? ive heard many people set up 800mhz radios to scan, but not able to transmit due to them not being a user on the system.
J
jerk
jerkville
J
Because they can monitor each and every radio on the system and which site the radio is connecting to as you travel around. So if you live in Northern Marion County, but you radio is affiliated to a South group, it sticks out. Duplicate id’s stick out. Radios turned on at odd hours stick out. And when the radio comes on that is not authorized, the administrators can “brick” or disable the radio. The only way it can be repaired is by sending it to Motorola Depot, and you’ll have to explain why you need it repaired.
The XTS500 auto-affiliates with the 96k radio system. You can’t disable that feature like you can on older systems and radios.
But if money is not object, I say go for it. Just don’t expect good results. But I think you’ll find the administrators quite competent in doing their job. And after they contact the legitimate user, your radio will be a nice doorstop.
AL
kareem2o
That make's a lot of cense, I would'nt challenge your knowledge. Good info newsalan.
Seanb508 I did some research on the BC996; its a good radio...
seanb580
Carmel, In
kareem....yes it is, I just purchased one and love it. I guess if money isn't a factor then I say go for it!
Update on MECA testing P25 not Necessarily for SYS 2 current talk groups being used for testing and freqs. Word is they still have a pending app for the new system just testing right now on some open freqs. So I quess we will wait and see.
856.1625 856.5125 857.6625 858.1875
Testing TG
10012
10013
10015
10018
10021
10024
10025
10102
10103
10104
10105
10106
10109
10122
10124
10125
10202
10203
10204
10241
10255
10256
10261
10902
20302
seanb580
Carmel, In
does anyone have the tg id's for Ops 21, 22, 23? They aren't in the database for some reason and they are still in use.
aaron315
8368* 20b* A* MC-OP21* WASHINGTON TWP FG-1*
8384* 20c* A* MC-OP22* WASHINGTON TWP FG-2*
8400* 20d* A* MC-OP23* WASHINGTON TWP FG-3*
seanb580
Carmel, In
scanner freak.......
can we get these tg back into the database? they are currently being used.
Those are now called
IFD OPS 21
IFD OPS 22
IFD OPS 23
and you are correct those are being used a lot still
seanb580
Carmel, In
yeah, its just the same with the old warren tg's, they are still using the 41,42,43 format....weird thing is, the 4x tg's are still in the database, the 2x have been removed.
I think that is because some fire guy with IFD posted or sumited a new list witch was wrong info and then they changed the DB going by his list that was wrong but oh well
I know Hamilton County use the ops 21,22,23 a lot patched to IFD when they help IFD
