I am having an issue with OP25 (Boatbod) that it crashes mid conversation at random times.
Sometimes it runs for 3hrs without any issues and sometimes it crashes after 10 mins.
I added below a copy of my stderr.4 file (I had to cut some parts because the message was too long)
Code:
Using Python /usr/bin/python2
Configuring audio instance #0 [audio0]
using ALSA sound system
audio device: default
Listening on 127.0.0.1:23466
10/04/22 11:22:35.575346 [SERAM] Initializing P25 system
10/04/22 11:22:35.575607 [SERAM] reading system tgid_tags_file: montreal.tsv
10/04/22 11:22:35.649910 [SERAM] setting tgid(50001), prio(4), tag(Regroupement 1)
10/04/22 11:22:35.650325 [SERAM] setting tgid(50002), prio(4), tag(Regroupement 2)
10/04/22 11:22:35.650657 [SERAM] setting tgid(50003), prio(4), tag(Regroupement 3)
10/04/22 11:22:35.650986 [SERAM] setting tgid(50004), prio(4), tag(Regroupement 4)
10/04/22 11:22:35.652325 [SERAM] setting tgid(60041), prio(2), tag(Repartition)
10/04/22 11:22:35.652501 [SERAM] setting tgid(60042), prio(2), tag(Premier Repondants A)
10/04/22 11:22:35.652668 [SERAM] setting tgid(60043), prio(2), tag(Premier Repondants B)
10/04/22 11:22:35.652822 [SERAM] setting tgid(60051), prio(2), tag(COMMANDEMENT 3)
10/04/22 11:22:35.652963 [SERAM] setting tgid(60052), prio(2), tag(COMMANDEMENT 4)
10/04/22 11:22:35.653097 [SERAM] setting tgid(60053), prio(2), tag(COMMANDEMENT 5)
10/04/22 11:22:35.653235 [SERAM] setting tgid(60054), prio(2), tag(COMMANDEMENT 6)
10/04/22 11:22:35.653380 [SERAM] setting tgid(60055), prio(2), tag(COMMANDEMENT 7)
10/04/22 11:22:35.653518 [SERAM] setting tgid(60056), prio(2), tag(COMMANDEMENT 8)
10/04/22 11:22:35.653661 [SERAM] setting tgid(60057), prio(2), tag(COMMANDEMENT 14)
10/04/22 11:22:35.653815 [SERAM] setting tgid(60058), prio(4), tag(Poste de Commandement A)
10/04/22 11:22:35.653953 [SERAM] setting tgid(60059), prio(2), tag(COMMANDEMENT 11)
10/04/22 11:22:35.686933 [SERAM] reading system rid_tags_file: mtl-rid.tsv
10/04/22 11:22:35.775888 [SERAM] setting rid(25099), tag(Quebec 511)
10/04/22 11:22:35.776052 [SERAM] reading system whitelist file: seram.wlist
10/04/22 11:22:35.781740 [SERAM] added talkgroup 60051 from seram.wlist
10/04/22 11:22:35.782084 [SERAM] added talkgroup 60052 from seram.wlist
10/04/22 11:22:35.782250 [SERAM] added talkgroup 60053 from seram.wlist
10/04/22 11:22:35.782364 [SERAM] added talkgroup 60054 from seram.wlist
10/04/22 11:22:35.782463 [SERAM] added talkgroup 60055 from seram.wlist
10/04/22 11:22:35.782560 [SERAM] added talkgroup 60056 from seram.wlist
10/04/22 11:22:35.782653 [SERAM] added talkgroup 60057 from seram.wlist
10/04/22 11:22:35.782741 [SERAM] added talkgroup 60059 from seram.wlist
10/04/22 11:22:35.782828 [SERAM] added talkgroup 60091 from seram.wlist
10/04/22 11:22:35.782915 [SERAM] added talkgroup 60092 from seram.wlist
10/04/22 11:22:35.783174 [SERAM] added talkgroup 60041 from seram.wlist
10/04/22 11:22:35.783262 [SERAM] added talkgroup 60042 from seram.wlist
10/04/22 11:22:35.783347 [SERAM] added talkgroup 60043 from seram.wlist
10/04/22 11:22:35.783432 [SERAM] added talkgroup 50001 from seram.wlist
10/04/22 11:22:35.783519 [SERAM] added talkgroup 50002 from seram.wlist
10/04/22 11:22:35.783605 [SERAM] added talkgroup 50003 from seram.wlist
10/04/22 11:22:35.783692 [SERAM] added talkgroup 50004 from seram.wlist
Enabled trunking module: tk_p25.py
device: {u'args': u'rtl=0', u'gain_mode': False, u'gains': u'LNA:248', u'usable_bw_pct': 0.85, u'ppm': 0.0, u'rate': 2400000, u'tunable': True, u'offset': 0, u'name': u'sdr0'}
Device name: "sdr0", osmosdr args: "rtl=0"
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.13.4
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gr-osmosdr driver gain_mode: False
channel (dev sdr0): {u'plot': u'', u'cqpsk_tracking': True, u'name': u'SERAM Public Safety', u'demod_type': u'cqpsk', u'tracking_feedback': 0.85, u'destination': u'udp://127.0.0.1:23466', u'excess_bw': 0.2, u'trunking_sysname': u'SERAM', u'filter_type': u'rc', u'blacklist': u'', u'device': u'sdr0', u'symbol_rate': 4800, u'frequency': 770506250, u'tracking_threshold': 30, u'meta_stream_name': u'metastream_0', u'if_rate': 24000, u'whitelist': u'seram.wlist', u'enable_analog': u'off'}
Using two-stage decimator for speed=2400000, decim=25/4 if1=96000 if2=24000
op25_audio::open_socket(): enabled udp host(127.0.0.1), wireshark(23466), audio(23466)
10/04/22 11:22:37.402687 [0] Unable to initialize demod to freq: 770506250, using device freq: 800000000
10/04/22 11:22:37.405937 [0] Initializing P25 receiver: SERAM Public Safety
10/04/22 11:22:37.407023 [0] metadata updates not enabled
10/04/22 11:22:37.408521 [0] reading channel whitelist file: seram.wlist
10/04/22 11:22:37.411924 [0] added talkgroup 60051 from seram.wlist
10/04/22 11:22:37.412998 [0] added talkgroup 60052 from seram.wlist
10/04/22 11:22:37.415223 [0] added talkgroup 60053 from seram.wlist
10/04/22 11:22:37.415607 [0] added talkgroup 60054 from seram.wlist
10/04/22 11:22:37.416345 [0] added talkgroup 60055 from seram.wlist
10/04/22 11:22:37.416612 [0] added talkgroup 60056 from seram.wlist
10/04/22 11:22:37.416828 [0] added talkgroup 60057 from seram.wlist
10/04/22 11:22:37.417010 [0] added talkgroup 60059 from seram.wlist
10/04/22 11:22:37.417182 [0] added talkgroup 60091 from seram.wlist
10/04/22 11:22:37.417354 [0] added talkgroup 60092 from seram.wlist
10/04/22 11:22:37.417822 [0] added talkgroup 60041 from seram.wlist
10/04/22 11:22:37.417968 [0] added talkgroup 60042 from seram.wlist
10/04/22 11:22:37.418112 [0] added talkgroup 60043 from seram.wlist
10/04/22 11:22:37.418257 [0] added talkgroup 50001 from seram.wlist
10/04/22 11:22:37.418403 [0] added talkgroup 50002 from seram.wlist
10/04/22 11:22:37.418558 [0] added talkgroup 50003 from seram.wlist
10/04/22 11:22:37.418705 [0] added talkgroup 50004 from seram.wlist
python version detected: 2.7.16 (default, Oct 10 2019, 22:02:15)
[GCC 8.3.0]
Allocating 15 zero-copy buffers
10/05/22 16:03:59.836855 [0] control channel timeout, freq(770.756250)
10/05/22 16:04:00.874020 [0] control channel timeout, freq(770.756250)
10/05/22 16:04:01.911698 [0] control channel timeout, freq(770.756250)
10/05/22 16:04:41.022242 [0] voice update: tg(60041), rid(700119), freq(772.006250), slot(-), prio(2)
10/05/22 16:04:41.245820 [0] releasing: tg(60041), freq(772.006250), slot(-), reason(duid15)
10/05/22 16:04:42.059528 [0] voice update: tg(60041), rid(0), freq(772.006250), slot(-), prio(2)
10/05/22 16:14:01.183540 PCM underrun
10/05/22 16:27:36.635655 [0] voice update: tg(50001), rid(700120), freq(770.506250), slot(1), prio(4)
10/05/22 16:27:45.476716 [0] releasing: tg(50001), freq(770.506250), slot(1), reason(duid15)
10/05/22 16:28:16.873395 [0] voice update: tg(60091), rid(702099), freq(770.506250), slot(1), prio(2)
10/05/22 16:29:40.844627 PCM underrun
10/05/22 16:42:55.620050 [0] voice update: tg(60041), rid(700360), freq(770.756250), slot(1), prio(2)
10/05/22 16:43:00.216617 [0] releasing: tg(60041), freq(770.756250), slot(1), reason(duid15)
10/05/22 16:43:02.448930 [0] voice update: tg(60041), rid(702099), freq(770.756250), slot(1), prio(2)
10/05/22 16:43:05.832378 PCM underrun
10/05/22 16:43:14.517018 [0] releasing: tg(60041), freq(770.756250), slot(1), reason(duid15)
10/05/22 16:43:21.408529 [0] voice update: tg(60041), rid(0), freq(770.506250), slot(0), prio(2)
10/05/22 16:43:38.978856 [0] releasing: tg(60041), freq(770.506250), slot(0), reason(duid15)
10/05/22 16:58:34.822618 [0] voice update: tg(60041), rid(701843), freq(770.756250), slot(0), prio(2)
10/05/22 16:58:56.733375 [0] releasing: tg(60041), freq(770.756250), slot(0), reason(duid15)
10/05/22 16:59:04.531200 [0] voice update: tg(60041), rid(702099), freq(770.506250), slot(1), prio(2)
10/05/22 17:00:09.242840 PCM underrun
10/05/22 17:00:12.417277 [0] releasing: tg(60041), freq(770.756250), slot(0), reason(duid15)
10/05/22 17:00:17.495353 [0] voice update: tg(60041), rid(701843), freq(772.256250), slot(0), prio(2)
10/05/22 17:00:31.367393 [0] releasing: tg(60041), freq(772.256250), slot(0), reason(duid15)
10/05/22 17:04:55.806285 PCM underrun
10/05/22 17:05:06.562213 [0] releasing: tg(60041), freq(770.756250), slot(0), reason(duid15)
10/05/22 17:05:08.703687 [0] voice update: tg(50002), rid(0), freq(770.756250), slot(0), prio(4)
10/05/22 17:05:15.193836 [0] releasing: tg(50002), freq(770.756250), slot(0), reason(duid15)
10/05/22 17:20:08.907622 PCM underrun
10/05/22 17:25:56.523303 [0] voice update: tg(60059), rid(0), freq(770.506250), slot(0), prio(2)
10/05/22 17:26:00.452924 [0] releasing: tg(60059), freq(770.506250), slot(0), reason(duid15)
