OP25 OP25 on Windows subsystem for Linux
maus92
OCMD
I am very interested to see the result.
wgbecks
NE Wisconsin
Has anyone tried this out for running op25 on windows?
I am trying it out right now and will let everyone know how it goes.
This is not a new concept. OP25 runs very well in Linux on a Virtual Machine.
plusEric26
Southwest Ohio
I tried to get this working. I couldn't get gnuradio to work. I'm no linux expert though.
I first tried installing gnuradio the standard way through packages. Didn't work. I tried compiling from source and found quite a few things missing to do even that, after fixing them it seemed to work but yet op25 still had errors related to gnuradio (although different ones) after I finally got it to compile.
I might try again, but it seems like it won't be very straight forward at all, if it will work.
I did this with ubuntu on WSL.
maus92
OCMD
Did you use the Boatbod version / method? It's a lot easier.
hamfan22
Houston, Texas
After quite a bit of tinkering, I have not found a way to make it work. I installed the boatbod version of op25 and the install worked, but I ran into the issue of getting ubuntu to recognize the rtlsdr. Using lsusb doest't produce anything, so the big hurdle will be getting the sdr into ubuntu. I did see an article that WSL supports serial devices, so that could be an option?
DRL-XM43
Durham Region
I hit the same wall with it - also it is tough working with just a command line with no form of interface.
belvdr
There were significant limitations in WSL v1. I suspect better luck would be had with WSL2.
boatbod
Talbot Co, MD
I searched around a bit and cannot find anything to suggest that USB Pass-through is supported in WSL. Without that there would be no way to load the RTL driver.
DRL-XM43
Durham Region
This person managed to get their NooElec SDR working in the WSL. WSL and SDR in Windows 10 I'm trying it to see if it works.
WSL2 is probably the key - I notice he had a GUI interface I did not have one with WSL1 - anyway I don't doubt he managed to brow beat the OS into submission.... but after reading several pages I opted to stick with OP25 on my VM for now (it works wonderfully)
However I have been known to get personal with this type of project and I can see myself on a long and bitter winter night torturing myself to make it go :) Just cus someone said it can be done lol.
wgbecks
NE Wisconsin
No need to torture yourself. Download and install Oracle VirtualBox the install your favorite Linux distro as a Virtual Machine. Works fine lasts a long time!
DRL-XM43
Durham Region
As my post noted that's what I do.
DRL-XM43
Durham Region
Apparently WSL2 will not be public available til after April.
I am still not sure if it will directly support or have a GUI capability, utilities, sound, usb device recognition even then....
(thinks to self... stock up on duct tape, baling wire and make sure the cuss jar is handy for possible summer project.)
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I'm pretty tempted to update to the latest insider build. Easy enough to restore from backup. But I haven't taken the plunge yet.
m
