Orion Fix
Muxlow
Super Secret
Middlesex County
Got a new orion and it dont work. All the things you boys told me are fine..
So i was looking on the PA unit on the red wire to the place it connects to the board.
And i see that R49 has some burn marks around it.
What does that do and how can it be fixed? Or to make sure that really is the problem?
JungleJim
R49 is the termistor used to sense the heat of final and back off the power when it gets too hot. If it got fried you may have had a pretty bad meltdown. The other possibility is that the power transistor(s) may have been replaced and whoever did it didn't clean it up well. In either case though I don't think it would keep your radio from powering up.
What is the power rating of the amp, 20W, 40W or 100W?
JungleJim
The 20W will have the black brick as the RF final amplifier. The 45W will have the black brick followed by a single RF power transistor (white circle with six leads). The 100W has that with the addition of two more power transistors in parallel for the final.
