codymw623
Ebensburg PA
Hello,
I am looking for assistance on programming a Unication G5 UHF-7/800mhz. Before anyone slams me, I had bought this off eBay from a unication dealer and they will not provide programming assistance, since they are not from the area. I have had this receiver/pager for about two weeks. I have 5 stations that need alerting. All p25 conventional with nothing fancy. 2 of the 5 stations alert as they should, but the other 3 will not. I have the correct tone formats and tone spacing. I am stuck at a wall and cannot figure out what i am doing wrong. I placed the tone formats into the p25C tone subgroups appropriately and also created a protocol for each individual group of tone formats with the proper timing.
I am not sure what I am missing or doing wrong. I looked at the material provided from unication I regards to 2 tone programming (mostly all trunking) and still cannot get anywhere.
Any help will be greatly appreciated.
Thank you,
Cody
codymw623
Ebensburg PA
Attached files shows the programming. The protocols that are selected are the ones not working properly.7A3A5EAE-0CE2-4010-B549-12F5CFCCF32C.jpeg0132B9AB-233F-41D4-83D9-9A37FC902002.jpegD2BFFCA6-C2DE-4082-8936-AE694DCA8267.jpeg
RBMTS
Have you updated your radio firmware? I believe there was issues with P25 conventional tone on older 1.2 and earlier firmware versions.
RBMTS
Maybe try putting only one of the troublesome tone frequency setups on its own switch setting and turn priority off. In other words, look at only 1 of them at a time to see if you can get it to work properly.
You stated that the tone pairs are correct. Do you know that for being dead-on correct? I’ve seen that claim before and there was usually an error. Not saying that you are wrong but if some of the tones work and some don’t, I’m leaning towards an error with the tone list you have.
Keep trying. It usually just takes some trial and error experimentation.
codymw623
Ebensburg PA
It maybe an error. Unfortunately these tone formats are from when the system i am monitoring was analog, maybe they changed the formats when it went to p25.
Another question for you. So the system i monitor is actually the county i work in as a Paramedic. I have an XTS5000 that i carry daily. The 911 center programmed my ASTRO ID into their alerting system. So like 1 second before the tones are activated my portable radio will give 3 consecutive beeps saying ASTRO Call received. Is there a way to do something similar on the Unication pager? I messed around a bit with the TGID in the group id settings, but don't see anything that fits the criteria.
codymw623
Ebensburg PA
The other thing i just realized. My tone formats are literally just reversed. I manually generated them in a tone generator and listened to pre-recorded tones and they are the same.
For example. Station 400 669.9/928.1, Station 440 928.1/669.9.
Could that be the issue?
codymw623
Ebensburg PA
Yes I have tried that. I have tried tone pairs above and below the pair I have programmed in and no success.
codymw623
Ebensburg PA
Do you guys know if there is a way to program multiple private call IDs. It is the 2nd tab next to group ID. Or is there a way to edit the talk group in the actual device menu settings. I see the option, but it is blank and not editable.
kford211
Fulton County, Pennsylvania
Have you had any luck getting it to work? I have the same G5 pager. I might enter the tones you posted in mine and see if it alerts next time I'm in Blair County.
billyfromhill
I'm trying to get this to work also. As far as I can tell you are only able to have a single Private Call ID. I don't believe P25 call alerts support wildcards either because "F" is a valid hexadecimal character in a P25 ID. It would be nice to add additional private call entries so I can page groups of my users without having to transmit a dozen or more call alerts, one to each pager.
