P25RX-II P25RX-II Firmware Updates / Testing
bagmouse7
NC, USA
I will get this thread going again with a couple of feature requests.
1. On the Alias tab for the radio IDs can you add an "Export CSV" function.
2. On the same Alias tab, when you discover a new Radio ID and put it at the bottom of the list, can you add a column for the talk group that you saw the new RID on? Adding the talk group makes it easier to identify the radio ID.
Thanks!
  • Like
Reactions: btt
MStep
New York City
I will throw in a request as well. On the Search DB tab, in addition to the current "Test Selected Frequencies" button, perhaps next to that you can add a "Test All Frequencies" button. Just makes it a bit easier to accomplish when you get a lot of hits from the database in a place like NYC.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Thanks!
I will add these to the list. Thank you.
EMwaves54
My RX-II took in a firmware update today upon. The unit was getting hot and seems to be running much cooler now.
EMwaves54
My RX-II does fine with BT headphones but when driving all the audio pauses have me constantly fiddling to reconnect. Would I get better connectivity if instead of stream pause it just push keep sending something at low volume?
btt
Banned
Banned
Wa State
I'm guessing that Bluetooth was disabled on the firmware update. Bluetooth does add some extra warmth to the device. This is normal.
The P25RX-II does send a periodic (very low volume) signal over Bluetooth with the intent of keeping Bluetooth sink devices (speakers, headphones) from going into a sleep mode.
EMwaves54
I just checked and Bluetooth is on and still shows enabled on startup. I am on BT headphones now and it currently running much cooler than before.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Todd,
Anything further on porting the P25RX-II features over to the original P25RX model?
I'm still working on getting the new features released for the P25RX-II. After it is released, my plan is to start working on a version of the application that contains the firmware for both models. Hoping to have a P25RX-II release possibly this week or weekend. These are going to be big changes in order to support the new modulations and scanning. I'm sure not everyone will be happy with the added complexity. I may still need to maintain two or more versions (advanced and easier-to-use versions). Even though there is added complexity, I'm shooting for making the latest version more intuitive. We'll see how it goes.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
Todd,
You ROCK !...Keep going, Those who are having difficulty keeping up will eventually do it.. With all of the help afforded by YOU and this forum, I can't see how anyone will be left behind.. Just my .02..
Dave
kruser
Well Known Member
W St Louis Cnty, MO
Thanks Todd! That all sounds fantastic and hopefully it will be easy for you!
In full disclosure, I've been away from my radios lately and not had the time to use them 24x7 like I normally do.
I still use my P25RX though as it works so darn well on the simulcast system I monitor as well as the non-simulcast VHF system I monitor. Both P25 Phase I systems.
I'll let the P25RX just do it's thing sometimes when I'm away for more than a day. Then I can look at the TG Editor screen and see if any new unknown TGs were found. So far, doing that has found a few rarely used TGs that I can name correctly.
Thanks Again for all you do!
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Hopefully you are just busy with other things, and everything is going good in MO!
dcr_inc
Delta, Pa
Todd,
Can the P25RXII have the "allow unknown TG" turned on by system or is it all on or all off? Maybe a nice feature to have if its all on all off. Just a thought (like you need more to do, Sorry)
  • Like
Reactions: btt
