CQPSK is selected.
P25RX-II dBm range -100 to 90dBm (roughly 2.5 bars);
SDR (Nooelec) -41dB to -40 dB steady;
SDS -60dBm steady (full bars.)
I'll pull some data of a G5 when I get a chance, but it's using the stock antenna system and works flawlessly, so likely is not helpful.
Thank you for the details and observations! I'm going to be pretty busy today and tomorrow, but I will get back to the firmware after that. I'll dig into what might have changed with DMR. That have been so many changes these past couple of months. I did test DMR here on a Con+ system, but I may have missed something.My observation with Con+ systems on yesterday and today's firmware. I recognize my experience with Con+ may be different than those monitoring trunked P25.
On systems with moderate to strong signal, everything is great with default settings both stationary and mobile.
However, on weaker systems the RX-II with current FW seems to struggle vs the Rx-I (running 2022-01-09 09:46). Many times the RX-II will show decent signal level (typically within 5 dBm of the RX-I), Sync, and show DMR CC BLKS_SEC of >30 (which historically is sufficient for good decode). However, the RX-II will either completely miss the voice call (console log shows no sign of voice call), or the voice call will be recognized but no audio decoded.
Here is a comparison of what I'm currently seeing on the same Con+ System:
Although I'm not in a weak signal area, I do notice some significant improvement in several areas with this new version. The ERR is down to 0.000 almost all the time and the EVM is down to 2%.If you are using the LSM demodulation option to monitor a P25 simulcast system, it is recommended to update to 01-24_0649. In testing this improvement against the various IQ files that have been sent in from challenging locations, the improvement is significant.
Sounds good !@kb8q, thank you for testing the latest. I'm going to continue with getting the scanning profile support added to the P25RX-II model first, then I will work on getting all the updates into the orginal model.
Sorry about that. That page was getting really cluttered with all the massive changes lately. I added a "tool tip" text to the buttons. If you hover the mouse over the button, it will show "Press Shift While Pressing Button To Set Zone Alias".Todd did you post somewhere that you can give the zone buttons an alias?
Yes.Hi Todd... will scanning support include the ability to scan conventional VHF narrow-band FM frequencies along with 700/800 MHz P2 systems?
Yes.
Yes, I drove all over the place today with the latest firmware. I drove by several cell phone towers (no issues). I saw RSSI values from -120 dBm to -67 dBm show up on the LCD panel for the 9-site LSM system here. It is working good.Version 01-24-1017 seems to have fixed the inaccurate RSSI indication. Burning it in now, and with test more extensively later tonight or tomorrow.
It looks like the link has been updated for _1741 now. Downloading/updating now.Running 01-28_1242 currently. It's doing good here stationary. I don't see 01-28_1741 listed.
