arbitergvadam
San antonio
I have several radios with the following model number HT71508U1X and features installed
7
8
9
10
23
I was curious to see if there was a way in RPM or programmer to edit the features and add in P25 conventional. If so what is the name of the software that can do this and what would be the protocol for changing this. If not and its a Harris only thing then thanks for the answer in advance.
merlin
DN32su
No, features and feature strings have to be processed and downloaded from Harris. The P7100 is no longer supported.
What people have been doing is buying another P7100 that has all the features you are looking for (does not hve to be the same band model)
But should have the same or later firmware.
Then swapping the ESN chip and copying the encrypted feature string.
RPM works fine for the task after the chip swap and use Maintenance to edit the feature string.
Echo4Thirty
Spring,TX
This is exactly what folks i know did. They bought a useless UHF Low split (403-433) that had a nice loaded P25 trunked set and transplanted it into my VHF that was analog only. The soldering isnt bad if you have experience with board level repair and it was trivial to transplant the feature string. You can also transplant a P7100 into an M7100 to upgrade the super cheap 110w VHF mobiles floating around. Same chip, same process.
KevinC
The big K
Super Moderator
Home
I'm going to try that on my APX MACE.
