Thanks. Now I'm even more confused. Are they narrow banding the VHF or getting rid of it completely in another year? I'm not sure if PSP even knows this given the conflicting information.
Sent from my iPad using Tapatalk
Because its existing VHF radio system consists of 2,500 mobile units, 1,200 portable units, 80 dispatch systems, and 109 VHF base stations,10 PSP and OPRS determined that it would be cost-prohibitive to completely narrowband the statewide VHF system, given that PSP plans to decommission this system once the 800 MHz PA-STARNET system is completed.11
Since then, PSP has improved its VHF system by purchasing some narrowband-compliant mobile radios and dispatch equipment, and has secured narrowband emission designators for its licenses. It estimates that these improvements to the VHF system will be complete by the end of 2012. PSP also included funding for narrowband-compliant equipment in its budget for Fiscal Year 2012-2013.
The text of the FCC document indicates to me that another STRANET deadline has been set in December, 2013 for the system to meet PSP's needs. PSP plans to maintain their old VHF until that point when, according to this, the old VHF will be decommissioned. Since they only plan to continue using the VHF for one more year, they are requesting to continue working wideband instead of spending a bunch of money they don't really have on narrowbanding a system being phased out.
From the linked document:
PSP states that its 800 MHz system is incomplete and experiences most outages
in areas where rough terrain inhibits construction of fully hardened sites. PSP has added fully
hardened 800 MHz sites over the past few years to increase interoperability, and 217 of such sites
currently provide coverage to 85 percent of Pennsylvania’s total land area. PSP wishes to retain
its legacy VHF system until the 800 MHz PA-STARNET system is fully tested. In 2011 PSP
and the Pennsylvania Office of Public Radio Services (OPRS) evaluated the feasibility of
maintaining the current VHF system on an interim basis. Because its existing VHF radio system
stations, PSP and OPRS determined that it would be cost-prohibitive to completely narrowband
PA-STARNET system is completed. Accordingly, PSP seeks a waiver to continue to use its
existing VHF system beyond the Commission’s January 1, 2013 narrowbanding deadline, until its
800 MHz system is fully operable on December 31, 2013.
Well, except for these two bits (emphasis added by me):
and
So they clearly have replaced some of the VHF equipment with newer narrowband capable hardware, and apparently plan to continue to do so this year. I assume they are going to retain some VHF capability in some of the areas OpenSky has coverage issues. It would be silly to buy some new VHF hardware, only to discard it within a year or two.
Considering that they are supposed to be installing new dualband mobiles, I figured their intention was to maintain direct voice comms with other public safety agencies using these radios. It really sounds like the intention is to not keep the PSP VHF long term. But, the new equipment would allow quick and easy interop in some areas going forward.
OK so I have A a friend that bought a thousand or so of the old Syntorx 9000 radios and they each came in the box of the replacement radios the APX7500 features listed are for the 700/800 are TDMA. So the cars are using TDMA Slot 2 so that should be decodeable. They are also dualband with VHF being the secondary band.
Doug
They took out a lot of new licenses for what some have indicated is a new Back-up system. Many of them were combined with a DCNR license where they often show VHF Repeaters. Here's one for Dunmore: KXH342 Here's one that has repeaters on 155.5800, the older(15-20 yrs ago) freq for your area. WQLN816 Notice that this is a DCNR license FRN 0003178472while in the truck earlier i heard comms on Channel G Dispatch Base/Mobiles 155.445 186.2pl im a bit confused though because that lisence shows cancelled in the database.
You may remember, back in the "OLD" days (not too long after they went from low band to VHF), a few troopers did actually print out their list for friends, and it was published on one or more forums.Would love to get a channel list from there apx's from each barrack!
