Pinellas County P25 (802.BEE00) and Clearwater (00A.91F81)
CanesFan95
Was Homeboys-Scanna
FL
Those should probably be taken out of the RR database. If CPD is a Harris system, then anytime TGs are patched together, the system grabs the next available 65xxx ID and that's the TGID you might see. The specific 65xxx number can change to anything as patches are removed and added.
For you, I would just ignore the 65xxx's. Just use the regular TGIDs like Group 11, Group 13, etc. Even if they get patched, most scanners will still hear the audio on the original TGID.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
Admin comment: This took me a hot minute to figure out that Clearwater has their own system independent from the Pinellas County system.
I agree, those 65xxx channels should not be listed in the RR dB - will clean this up.
also, this master thread title has been updated to address these two systems in one thread.
railroader1994
I cannot figure out what I am doing wrong with Clearwater pd on their independent system. I have used database info to program but it has been silence for some reason.
CanesFan95
Was Homeboys-Scanna
FL
How long have you been listening? The Clearwater system is very slow sometimes.
mitbr
Tampa Bay Florida
1 alpha disp with dead carrier anyone else hearing this 6/5/24 649pm. Tried 3 different radios same result.
Update... resolved at 704pm
mitbr
Tampa Bay Florida
Pinellas site 5 p25 decoding strong signal not stopping on any talkgroups all other sites working...is anyone else seeing this? 08/06/24 1210 pm
mitbr
Tampa Bay Florida
Site 5 is 5 bars for me from Pasco County -78db on my SDS100
Thanks for the reply... the sig here is full scale as well just not stopping any of the talkgroups are you hearing audio is it stopping on talkgroups?
baayers
Pinellas County FL
After making some changes to my programming, I noticed that I was not picking up a control channel on Site 2. I checked with my 325 and found the same so I realized something was going on. It was there a few days ago, so I went looking and found it. Site has moved to 700 MHz. Here is what I have found so far tonight. This info is from monitoring the control channel using my 325.
770.5125 CC 0102
771.5625
772.8625
773.1875
773.4375
773.9375
There may be other frequencies, but this is what I could get with the limited traffic on the site. In the 90 minutes I monitored the only traffic I saw was PCSO A-1 and Largo PD CH 1.
bravo14
Polk County FL
770.5125 CC 0102
771.5625
772.8625
773.1875
773.4375
773.9375
Was there a NAC number show up? Or is it Nac 800?
ccc530
Does anyone know what is going on with PC TRS? First, I stopped receiving anything from the site on Ulmerton (I’m less than 1/4 mile away). I then set up the sw site and that worked ok for almost a week. Now, that has stopped receiving. Yes, I have all control frequencies- in fact, all frequencies are programmed in, yet still no joy. What am I overlooking? Any ideas?
tampabaynews
Keeping your PIO busy
Florida
Can you be more specific on what sites you're referring to? I haven't noticed an issue. Monitoring sites 4 and 5.
