Polk, Hardee, Highlands and DeSoto County P25 (396.BEE00)
unc21rules
Good evening,
I live in Polk county florida, and have a bcd996p2 scanner. I have been doing as much research as I can, but I am still stuck on the simulcast issue. I have the control channels plugged in through free scan and want to listen to north east police dispatch only which I have loaded into scanner. However, I still get all the bus chatter and still get fire and ems calls even though those groups are not added to the scanner.
My question is there a way even though it is simulcast to be able to get it to only have groups of police, fire and ems and only hear them and not everything else.
Thank you for any help
Nasby
Ohio
Good evening,
Check to see if you have ID search on.
If so, it should be set to ID scan, not search.
tvengr
Well Known Member
Baltimore County, MD
Welcome to the Radio Reference forums! Here is a Polk County FreeSCAN file for you to see how to program your scanner. First, make sure you have saved any files you may have done already. The attached zipped file has all of the talkgroups for Polk County. You will be able to easily select what you want to scan by using quick keys. Each of the 10 groups has a quick key to toggle that group on and off. While scanning the system, press the scroll knob and then the quick key number of a group to toggle it on and off. The 2 sites have system quick keys. Pressing 1 on the keypad will toggle the PolkCo Simulcast site on and off. Pressing 2 will toggle the Bartow Aircraft site on and off. This file has a separate group for Polk Sheriff NE on group quick key 8. The remainder of the Sheriff talkgroups are in the PolkCo Sherff group on group quick key 9. There are 2 files attached. The first one is your FreeSCAN programming file. The second PDF file will answer all of your questions about using quick keys. Save the attached zipped file to your scanner and extract. Open the extracted file with FreeSCAN. Connect your computer and scanner with the programming cable. Go to the Scanner tab in FreeSCAN and click on Upload Programming. Select Erase All Systems & Settings (in red). That will clear everything in the scanner for a clean start. Click on Start Upload. Quick keys as follows:
SYSTEM QUICK KEYS:
1. PolkCo Simulcast (Site)
2. Bartow Aircraft (Site)
GROUP QUICK KEYS:
1. PolkCo Services
2. PolkCo Schools
3. PolkCo Interop
4. PolkCo Emerg Ops
5. PolkCo Fire/Resc
6. PolkCo Loc Fire
7. PolkCo Hosp Net
8. Polk Sheriff NE
9. PolkCo Sheriff
0. PolkCo Local PD
  • Polk Co FL FS.zip
  • Uniden Scanner Quick Key Instructions DMA.pdf
tvengr
Well Known Member
Please use this file instead. I noticed a typo in the system name.
  • Polk Co FL FS.zip
ke4crc
Lakeland, Fla.
Lima is Lake Wales city police. Lake Wales has its own city police BUT dispatch is contracted to the county.
The same goes for Haines City, Auburndale, & Winter Haven.
Hcy is NE
Aub & WH is on Central
the City Pd units have a 3-digit call sign.
a 4 digit with a letter AFTER the call sign is probably LT. a seria Sgt.
ke4crc
Lakeland, Fla.
Polk does not use encryption
From what I've heard (hearsay) most of the Staff members are Begging for ENC. BUT Grady has said no, Except for what Brovo noted 4 or 5 Channels that are
Grady has said he wants Transparency.
firerick100
wolcott ct
He’s awesome, I wish these other sheriffs would think like him , he’s the best
