Post Your Mystery Frequencies
ecps92
Taxachusetts
$031 - Cedar Hills
$032 - Dallas
$037 - Kilgore
$038 - Hillsboro
$043 - two locations of Montague and Dallas
$044 - DFW Metroplex
$05x series for Houston
Happy hunting
You might be receiving stuff from the DFW area since there has been good tropo conditions the past few days. You will have to keep an eye on them and see if the signal strength changes druing the day or if they disappear completely for long periods. That can be difficult to do because the feds usually don't talk that much.
The short data bursts on P25 conventional repeaters indicate they are probably part of an IP linked vote-scan system.
163.625, 163.700 & 170.9875 are probably CPB/ICE on one of the Cedar Hill TV towers but I don't know what NAC they are currently using there. They could be someplace else.
171.6625 is probably CBP/ICE or DEA.
165.2125 is used by the US Secret Service in a lot of places but could be something else. Years ago it was reported with NAC 001 at Bush's house in Dallas.
riverradio68
Tom, the skip was awesome this morning. Was tracking Seagoville FCI crystal clear which isn't an everyday occurrence.
Bill, thanks for that info. I figured the 031 was ICE but the capture of the C00 on 171.6625 was nice but still stumped who uses that NAC. Never seen the C00 NAC before.
410.800 731N is FPS I believe, got that with traffic from the Federal Courts in Sherman, TX.
Thanks Gentlemen!
ecps92
Taxachusetts
$C00 was likely coming from the East, been seen on that same Freq during band opennings in Atlanta [Circa 2014]
Thanks Gentlemen!
Larry51
Chesapeake, VA
165.2125 is MIKE frequency for the USSS. It's available for use nationwide, and is typically used for foreign heads of state or candidate protective details in Washington and around the country.b
riverradio68
Well, here is something to tear into. All acquired election day 100 miles NNE of Dallas. I have combed the wiki and identified some of it, but there is plenty that remains unknown. Unfortunately I do not have NAC or PL's to make identifying any easier but here is the list.
170.0000 ???/FBI 170.0000 None Digital Only Search False P25 167 False NFM
173.4500MHz 173.4500 None Digital Only Search False Search False NFM
167.6375MHz 167.6375 None Analog Only Search False Search False NFM
170.6625 FBI USA 170.6625 None Digital Only Search False Search False NFM
173.1000 ATF USA 173.1000 None Digital Only Off False P25 650 False NFM
164.5500 OCDETF1 164.5500 None Digital Only Off False P25 293 False NFM
170.7375MHz 170.7375 None Analog Only Search False Search False NFM
408.0375MHz 408.0375 None Analog Only Search False Search False NFM
173.1500MHz 173.1500 None Analog Only Search False Search False NFM
169.6000 FBI USA 169.6000 None Digital Only Off False P25 167 False NFM
169.9375MHz 169.9375 None Analog Only Search False Search False NFM
171.9875 FBI USA 171.9875 None Digital Only Off False P25 167 False NFM
164.1500 USFS AR 164.1500 None Analog Only 131.8 False Search False NFM
173.9875MHz 173.9875 None Analog Only Search False Search False NFM
165.9500 IRS DFW 165.9500 None Digital Only Search False Search False NFM
170.6750MHz 170.6750 None Analog Only Search False Search False NFM
172.2750 AN FIRE 172.2750 None Analog Only 100.0 False Search False NFM
400.5750MHz 400.5750 None Analog Only Search False Search False NFM
168.9875 FBI USA 168.9875 None Digital Only Off False P25 167 False NFM
402.6625MHz 402.6625 None Analog Only Search False Search False NFM
402.7000MHz 402.7000 None Analog Only Search False Search False NFM
173.0500MHz 173.0500 None Analog Only Search False Search False NFM
410.5500 VA HOSP 410.5500 None Digital Only Off False P25 293 False NFM
410.3000MHz 410.3000 None Analog Only Search False Search False NFM
402.6375MHz 402.6375 None Analog Only Search False Search False NFM
406.7375MHz 406.7375 None Analog Only Search False Search False NFM
400.0250MHz 400.0250 None Digital Only Off False Search False NFM
400.7375MHz 400.7375 None Digital Only Off False Search False NFM
418.0000MHz 418.0000 None Digital Only Off False Search False NFM
404.7375MHz 404.7375 None Digital Only Off False Search False NFM
170.9375MHz 170.9375 None Digital Only Off False Search False NFM
170.3750 FBI USA 170.3750 None Digital Only Off False P25 167 False NFM
164.7875 CBP/ICE 164.7875 None Digital Only Off False P25 169 False NFM
173.6375 FBI USA 173.6375 None Digital Only Search False P25 167 False NFM
401.1250MHz 401.1250 None Analog Only Search False Search False NFM
402.7625MHz 402.7625 None Analog Only Search False Search False NFM
170.8125 FBI DAL 170.8125 None Digital Only Search False P25 167 False NFM
170.5625MHz 170.5625 None Digital Only Off False P25 167 False NFM
172.8625MHz 172.8625 None Analog Only Search False Search False NFM
162.5375MHz 162.5375 None Analog Only Search False Search False NFM
165.3750 USSS TX 165.3750 None Digital Only Search False Search False NFM
163.2500MHz 163.2500 None Analog Only Search False Search False NFM
164.6500 USSS VP 164.6500 None Digital Only Search False Search False NFM
407.5000MHz 407.5000 None Digital Only Search False Search False NFM
163.7750MHz 163.7750 None Digital Only Off False P25 36 False NFM
410.8000 FPS MGA 410.8000 None Digital Only Off False P25 731 False NFM
168.9750MHz 168.9750 None Digital Only Off False P25 38 False NFM
166.2750MHz 166.2750 None Analog Only Search False Search False NFM
170.6250MHz 170.6250 None Digital Only Search False Search False NFM
169.4750 AN OTAR 169.4750 None Analog Only Search False Search False NFM
167.7125 FBI SAT 167.7125 None Digital Only Off False P25 167 False NFM
173.8125 FBI DAL 173.8125 None Digital Only Search False P25 167 False NFM
409.4500MHz 409.4500 None Analog Only Search False Search False NFM
172.2125 FBI HOU 172.2125 None Digital Only Off False P25 167 False NFM
408.1500MHz 408.1500 None Analog Only Search False Search False NFM
173.1625 FBI USA 173.1625 None Digital Only Off False P25 167 False NFM
163.6250 CBP/ICE 163.6250 None Digital Only Off False P25 32 False NFM
169.4250 AN OTAR 169.4250 None Analog Only Search False Search False NFM
165.2125 USSS MK 165.2125 None Digital Only Search False Search False NFM
407.2500MHz 407.2500 None Analog Only Search False Search False NFM
171.6625MHz 171.6625 None Digital Only Off False P25 C00 False NFM
170.9875 CBP/ICE 170.9875 None Digital Only Off False P25 44 False NFM
163.7000 CBP/ICE 163.7000 None Digital Only Off False P25 31 False NFM
406.5000 FCI SGV 406.5000 None Digital Only Off False P25 851 False NFM
171.6125 FBI DAL 171.6125 None Digital Only Off False P25 167 False NFM
406.8125 FCI TRS 406.8125 None Digital Only Off False P25 851 False NFM
KTEN NBC AUDIO 170.1500 None Analog Only 100.0 False Search False NFM
148.3500 CAP RPT 148.3500 None Digital Only Off False Search False NFM
414.7125MHz 414.7125 None Analog Only Search False Search False NFM
W3DMV
Gettysburg, Pa
Very good propagation from Gettysburg- Maryland & NVA. Many Integrated Wireless Network
signals received. This one eluded me and any info would be appreciated. Unable to find in a
extensive search.
164.8875 NAC 001 Sys 10. Anyone?
BM82557
Berkeley Co WV
extensive search.
I receive that one at my location, I believe it is USSS
wbloss
Human
Joplin MO
152.81 - a Part 22 freq - heard brief encoded NAC 293 TG2 with similar RIDs as often hear on 171.6875: 81610###, this one was 8164023.
171.6875 heard before 99% end but when un-enc mentions warrants and Kanas City.
Never seen a Part 22 used by feds!
FWIW YES I know MOSWIN uses both of these freqs but not low TG and Not these RIDs
any thoughts?
ecps92
Taxachusetts
152.8100 is not being used by the FEDS, where did you get that impression ??
Part 22 would be State/Local/County Governments but not licensed for FEDS, they go thru NTIA
any thoughts?
any thoughts?
NAC 293 is a generic NAC used when they are too lazy to program in another (like 023 PL code), I too have never seen Feds on Part 22.
wbloss
Human
Joplin MO
@ecps22 - your question is the same as mine....why is it here?
I recorded it and unless it is an image I wanted to see if anyone else had heard Feds here.
The fact that it has the same TG & RIDs as a regular Fed Freq made it more unusual.
I KNOW it is Part 22 (as I stated in my post) .
Stranger things have happened!
ecps92
Taxachusetts
No my question is/was
"Where do you get the impression that 152.8100 a Non Federal and Non NTIA Frequency are being
used by the Federal Government..."
How many hits, or was this a one-hit wonder?
I have seen many a scanner report a FALSE positive as well as have image issues.
and then the other comment I made was
Also 171.6875 is part of the Trunk system at multiple MO Sites which is an NTIA channel
turned over to the FCC for MO's system, as specific sites only.
signal500
K4DPS
Florida
any thoughts?
I believe you could have received a mixing / image on 152.81 MHz. Back in the early 90's, I would receive my local FBI on a 146 MHz frequency when they were actually using 167.4625. Just my 2 cents.
es93546
A Member Twice
Right Side of CA on maps
On the other hand federal agencies use state and local systems on a regular basis for coordination, not for day to day business. State and local agencies use federal systems for the same purposes. This is covered by interagency agreements, however the involved agencies don't build systems of their own using frequencies allocated for other levels of government. Since this was a brief reception it seems to match such use.
spacellamaman
i got a new one today, search and store 30-87mhz in fm mode got 53.825. tuned past it and heard clipped music, switched to wfm to hear country music. w/ seperate scanner ran thru 87-108 and it turned out to be 103.7fm broadcast.
BigLebowski
Piedmont NC
Logged the following in Northeast Lancaster County, PA on Sunday evening.. I believe it to be the Lebanon VA or Fort Indiantown Gap, but not sure.
169.0125 NAC 293 (100% secure)
171.0125 NAC 293 (clear, facilities-type traffic)
171.4125 NAC 293 (100% secure, busiest of all)
I have logged these before in Lebanon pretty strong as well.
RadioDitch
Field Operations Member
Not Where You Think
Just as a note. Most Fort Indiantown Gap and Muir AAF ground/base operations take place at this time on the State OpenSky TRS, which is being converted to P25 and integrated into the new system.
AM909
Radio/computer geek
SoCal
4-channel IDAS Area 0 trunk heard near Ontario, CA:
1: 407.346875
2: 407.834375
3: 408.034375
4: 409.371875
No traffic, just idle pulses.
BigLebowski
Piedmont NC
Good to know.. I don't make it up that way much but I figured this was either the Lebanon VA or FTIG. Maybe someone in the area can pinpoint it. "Building 17" was mentioned on the maintenance channel.
