President Washington. No Modulation.
K9KLC
Southwest, IL
Good point. While far from being a Collins, my Realistic TRC-30A would deadkey at 4W and only swing to about 5w. On the air, other stations said it was almost as loud as a heavily-modified Cobra 142 that I owned at the same time. The previous owner of the Cobra was a "golden screwdriver" who turned up the audio and took out the limiter. The Cobra had a lot of swing on the watt meter. The 30A seemed to be a fairly stock radio, but I have no idea if anything was done to it since I purchased it used. I used a D-104 TUG8 / TUG9 mics on both radios.
That's why I gave examples of the 148 and 2k, those were more radios that were not usually impressive on an "accurate wattmeter into a 50 Ohm dummy load" but yet were almost always louder. We can carry this back to other older tube type and early solid state models also. Gone are the days of clip the limiter and tune for maximum smoke. Somewhere, someone, somehow, got a clue and figured out what some of us knew all along. There's a time and place for a wattmeter and what it shows and then time for other test instruments.
EAFrizzle
Bond. Ward Bond
SE de DFW
I see at one point he had the carrier on AM up to 16 watts on the video so if it's only 10 now, yes I agree, something could have happened.
Yeah, that's the weird thing that's making me think it's some setting buried in the logic tree.
If this were my radio, I'd be fairly certain that I jacked something up (I like to mash all the buttons [and various combinations] to see what happens). This seems and feels to me like some sort of internal damage in transit. Need to know if it ever worked properly upon receipt; that'll narrow things down a bit.
K9KLC
Southwest, IL
Agreed.
kc2asb
NYC Area
I get it. I was just agreeing with your point about forward swing not always equaling the loudest audio. But, yes, that was my experience also - those Cobras along with the 142GTL/Washington/Madison were usually the loudest on the air. (and distorted/over-modulated)
K9KLC
Southwest, IL
Eh, not if set up correctly. But I digress, that didn't happen often. Also the term "over-modulated" is somewhat subject to interpretation. Is it over modulated on a scope, or on a meter, or to the receiver which may or may not hear things all the same? Also is the NB on on the radio, any other of this new fan dangled noise reduction circuitry? All of these things can change the way a radio hears as well as poor receive in general. But yes, a lot of CB's are over modulated no matter how you look it it.
K9KLC
Southwest, IL
You know what's funny, years and years ago, we never even worried about swing, especially in the tube days using wattmeters like the Drake W4. We tuned the radio (or amp or whatever) for maximum carrier and just talked on it. Heck, about 90% of the time, the Drake meter would swing down when you talked on it, not forward. Using scopes we could plainly see the radio had both positive and negative peaks but that meter back then sure didn't ever show it. I don't think I even heard of forward swing until sometime in the mid to late 80s. it wasn't something we ever worried about frankly or even heard of :)
jcrmadden
So have you gotten bad reports on audio the last couple of days?
No, I hadn't had anyone to say it sounded "bad" but I don't have a trusted set of ears around here. Lots of contacts but they all think the louder and boomier the better.
What "3 different radios"? Are they stock or where they set up by someone or what? Give us a little to go on here. What wattmeter, What load on the radios.
My Washington was one of the three. Both the other two were older Galaxy's. One is a Pluto. Not sure about the other. I was told that the Pluto hadn't been worked on since 1991, but that everything was bone stock (whatever that means).
The wattmeter was a Dosy TC4001P. Showed about a 4x swing from dead key to peak on both those Galaxy's and barely any on my Washington.
And I guess the last question is have you contacted the place you got the radio from and discussed this with them? If you posted you had, I apologize, I missed it.
I haven't yet. It was working fine when I got it. I've been running it a month or so.
I'll take this to mean you have not heard the radio. yourself yet, I'd start there and see what you think it sounds like.
This is the next step. I just got my QT60 back today so I'm going to put it in the wife's Yukon and listen to my boy yak on the Washington.
Out of curiosity what is the radio doing on FM?
Just shy of 40 watts, dead stable.
jcrmadden
I've never done business with Scott, but everything I've seen indicates he's a stand-up guy about his sales.
We've seen a video of it working fine. Did it ever work OK when you received it? If not, I'd suspect damage in transit. If it were mine or @slowmover 's rig, you could be sure we mashed the wrong button at the wrong time. 😎
Yeah, I've gotten a couple from him now and he's been great.
I've had the radio for about a month I think and it worked fine. BUT I never bothered putting it on a meter when I got it. Just pulled the QT60 out and slapped the Washington in.
slowmover
Fort Worth
$9.00
Toss second radio in back seat. Reduce RF power. No coax connected. Listen across quiet channel.
This is how I choose (1) of the (26?) mobile mics I have.
Great tip via Shadetree Mechanic at WWDX years ago.
EAFrizzle
Bond. Ward Bond
SE de DFW
Im sure it was just fine when he shipped it out, but what happened? I kinda want to look inside for a cold solder joint or a poofed diode. And that's aside from all the other things that can goober up a radio.
slowmover
Fort Worth
Edited Post #85 to include watt meter model number
Need a DAIWA 901 or other (powered) true PEP Meter, to be sure.
Reference Choice
I bought the 501 to help set up radio rig:
Be sure it runs on batt or DC.
— The DOSY meters ain’t worth much —
I ran my 945e about 12k miles before and after transition to QT60 with KL7505 amp. No antenna whack-a-doodle.
The 959 E-Z to run an amp. That was more about twin antenna set-up.
The 60W(?) QT60 I was more worried about in radio::amp match as antennas now ideal (short of having analyzer).
Correlated 945e with the D501 before leaving house. Cross-needle is the bees knees for adjustments any part of total system.
KL7505 = 225W Average and 265W PEP then divided by two antennas. (30A continuous). 10W Drive, max. So figure 100W per 8’ SIRIO.
EAFrizzle
Bond. Ward Bond
SE de DFW
OK, full power on FM with reduced output for AM makes me wonder about the modulation section. If your modulation is messed up, FM will still key at full power, it just won't have the same deviation. The audio will be way down on FM if that's part of the problem.
jcrmadden
I'm not so concerned about the modulation as I am about the loss of wattage. Sounding loud and having a strong signal are two different things.
Everything I'm reading in this thread is making me think about the PA stages instead of modulation. Of course, squirrely modulation will kill your output power, but something about this seems like a setting problem to me. Still could be some internal damage, though.
Have no idea what the dead key was set at when it left the shipper. He said it was from 1-10 when it arrived. People ask for strange things at times, as far as dead key goes. (or least they always did me back then). I may need to watch the video again and see if it was mentioned. As I stated, I'm not saying he's not having a problem, just would like a little more info. I'll go re-watch the video and see if "Scott" mentions what he set this at. Also I can't imagine not contacting the seller immediately upon arrival if he thought there was an issue, I am still waiting to hear if he did that.
This confusion is my fault. I was referencing the RF power "levels" as defined in the menu (e.g. 1 through 10). Not actual output watts.
My carrier watts are where they should be for each level (although not exactly linear).
The issue was that when I put it on the Dosy meter to read peak it wasn't swinging.
The only reason I had it on the meter was to dial DOWN the dead key to about 4 watts, and to make sure it wasn't swinging more that 100% modulation. That and I don't have a scope.
I've been through all the menu options about four separate times with menu in hand. I'm quite sure it isn't a settings issue.
Maybe it's a meter issue. Maybe it isn't an issue at all.
slowmover
Fort Worth
Ran out of time:
KL7505 = 225W Average and 265W PEP then divided by two antennas. (30A continuous). 10W Drive, max. So figure 100W per 8’ SIRIO at max radio drive.
Adjusted radio to deliver less than 10W (7-8?) and average output per antenna was still acceptably high (relative). “High” being that one wants big truck to match in performance what my pickup can do with single roof-mount and 45W.
PEP Meter a lifesaver. NANO-VNA on my list (or Rig Expert).
DC Clamp Ammeter another tool worth having.
What does it draw?
K9KLC
Southwest, IL
Ok so in recap, you have a radio you were talking on, nothing was wrong,(that you knew of) and you put is on Dosy meter to dial down the dead key and by that alone you decided there "may be" a problem with the radio? I just want to make sure I got this here.
"IF" the radio was set up correctly, (well at least in the case of most radios) with an adjustable carrier (dead key) you should be fine. Over modulation can be corrected by mic gain if that even ever becomes a factor.
