After my earlier post as the beep problem devolved into a constant beep whenever the radio was on, I started working on solutions. First, I tried to eliminate the obvious.
--Was the battery producing 9vdc or more?
--Were the battery connector/wire intact?
--Had any of the connecting polarity diodes failed?
I used a digital volt meter to trace the 9vdc path nearly all the way to IC-5. In my case, no problem was found.
Next, I tried the Draconian: I reset the CPU. This wasn't really a big deal since it was time for major reprogramming. However, it did NOT solve the battery beep problem.
I then rechecked this site and found the suggestion to ground out PIN 11 on connector CN3.
This seems to have solved the problem. I now have no LOW BATTERY blink display and no beep. I still have keypad beep.
What I did was to sever the PINK wire coming off PIN 11. I then soldered a jumper wire to GROUND using the nearest metal case as a ground point. The two severed ends were stripped about 1/8th of an inch and both soldered to the ground jumper. This was all.
Please note that BOTH ends of the severed pink wire need to be grounded.
I have three images showing the process that I will make available if anyone is interested. (These photos also show a previous discriminator tap that I put in for data reception.)
