PRO-2096 Digital decoding issues
Gregg251
Greensboro, NC
I just received by "repaired" scanner after 4 months at RS service in FL. But I still have the same problem. The scanner decodes digital signals for a few minutes to 1/2 hr after being turned on, then stops. All I hear is the raw digital feed on the APCO 25 channels. It seems like a heat problem, but I was hoping someone else had a similar experience and maybe a fix. Thanks, Gregg, N2UUP
Chattanooga, TN
My Pro 96 did kinda the same thing and still does from time to time.
I will be receiving well, then all of the sudden, it starts making the raw digital feed. I have to turn it off then back on. I still have firmware 1.2 on it, so I'm hoping when I update to 1.4, it will stop it.
Try turning the "ATT" on. It doesn't do it as much with the "ATT" on.
