countryfiregod
Hey All,
Im sitting here pulling what little hair I have left out , while programming a law enforcement friend's Pro-2096. I have programmed it the same way as I have programmed my own personal Pro-197 (which works perfectly) and I am not getting any audio on the Digital Talk Groups on the 2096.
For Example: I am programming in our county in WV for our new APCO 25 WVIRP Radio System
Bank 0 I programmed the 6 channels for the RIDGE(Hampshire) Site , which is what our local jurisdiction dispatches off of. Same six channels obviously that I programmed into my PRO-197 . I made certain to put the channels as MO, for Motorola Digital Channels.
I turned the bank into a Motorola Trunk Bank and programmed in the Talk Groups.
I turned the ATT on and the AGC off (Bear in mind I have tried those in multiple different positions "on,off")
I am not getting a DG signal when the talk group is active.
It is activating the system when a transmission is made , stopping on the appropriate talk group , but it is NOT making any audible noise or talking , therefore I can not hear the conversation on the appropriate talk group.
The conventional channels that I have programmed into different banks (not the same bank as the digital trunked channels) are working fine and volume works fine.
Also , when i go into manual mode certain control channels are in constant squelch, the other channels in the bank are not, but the control channels are always opened up.
I am not sure of the upgrade firmware version (anyone tell me how to find it and i will be able to answer that)
I have tried the scanner in different areas of the house to no avail, I have tried the antenna from my pro-197 to no avail. Depending on where in the house it is ranging from 18% to 98% on the control channel , and still not making proper audio when scanning and it comes up on a channel. Just thumbing through the individual channels using the MANUAL button it will occasionally pick up some activity , but not when scanning, obviously depending on what frequency is being used at that time by that talk group.
Any help would be appreciated
