zachful91
The only real issue I was having with my past configuration was IUPD was picking up slow and some of the others where also now much faster thank you
tvengr
Well Known Member
Baltimore County, MD
Give this file a try. Save the attached zipped file to your computer and extract. Open the extracted file with ARC96 and Upload to Scanner.
BANKS:
0. Monroe Conv
1. Hindustan
2. Bloomington
3. Knight Ridge
4. IN Univ Conv
  • Monroe Co IN 96.zip
zachful91
BANKS:
0. Monroe Conv
1. Hindustan
2. Bloomington
3. Knight Ridge
4. IN Univ Conv
do you have a file for
Uniden BCD536HP
i'm selling my BCD325P2
tvengr
Well Known Member
If the BCD325P2 works at your location, you can use a BCD996P2. That is the base/mobile version of the BCD325P2 and is less expensive than the BCD536HP.. You can use the same software and file as the 325P2 for programming it. Is the new file for your 2096 working OK?
zachful91
i was going to ask about the BCD996P2 and i gave the pro-2096 to my buddy the file worked tho
tvengr
Well Known Member
for some reason i can't pickup IU LTR system ???
SiteName
001 (1)Campus Bus System01 461.562503 464.8625
002 (2)Campus 800 Mhz System01 856.887509 858.887513 859.887517 860.8875
You need to set up a LTR system with 2 sites, one with the bus system frequencies and the other with the 800 mhz frequencies. The 2 digit number to the left of the frequency is the LCN or logical channel number. When you enter the frequencies, you must include the proper LCN with each frequency. Don't worry about bandplans with a LTR system. If available, you can use system quick key 5 for the bus system site and system quick 6 for the 800 mhz site. Here is a PDF file which should help you to better understand quick keys. Did you say the new 2096 file worked OK?
  • Uniden Scanner Quick Key Instructions..pdf
zachful91
SiteName
Yes the 2096 file was okay. And that's the proper LCN?
tvengr
Well Known Member
That is correct. LCN's on a LTR system are not required to be sequential and usually are not. You must enter the frequency along with its matching LCN.
zachful91
And I will only pickup if close right
tvengr
Well Known Member
That looks like it could be an old system. It may be deprecated. Attach your ARC-XT file and I will check it for problems.
zachful91
Bcd536hp is very slow returning back too amazon. My bcd325p2 is way faster..
When I find a bcd996p2 I'll buy it amazon are sold out
