There is a problem importing data for Zone 2 Ontario Fleenet system
Don S has reviewed the problem, here is his reply.
The DB is sending bad XML...
There is an ampersand in the county text for that system's Site 005. Win96's XML processor (necessarily) aborts when it sees this.
You might want to post a message on RR's "Eastern Canada" forum about this - some database admin is going to have to change the data.
-Don
You can also see the error yourself by entering this URL into Internet Explorer:
http://www.radioreference.com/apps/xml1.1/?sid=2560
The 2560 is the RR DB's "system ID", and is seen in the URL when you navigate to that system through the "normal" DB access:
http://www.radioreference.com/modul...=TRSDB&sid=2560
-Don
-Don
-Don
