derota
I programmed the control frequency for my county's p25 system into my scanner and I can't hear anything. It reads DG in the right top corner of the screen. Am I doing something wrong? I'm new to digital scanners.
When you programmed in the control channel did you have set as MOT?I programmed the control frequency for my county's p25 system into my scanner and I can't hear anything. It reads DG in the right top corner of the screen. Am I doing something wrong? I'm new to digital scanners.
Heres the manaul on programming the PRO 96 for digital system. http://support.radioshack.com/support_electronics/doc71/71778.pdf page33
Is your firmware updated in your scanner that helps decode the digital better?
Wish I could help you more. The only other thing I could think of is do you have it in open or closed mode?Yes, I followed the instruction when I first programmed it and by the way this is a simulcast system. My firmware is DSP-APP:U1.4
It looks like you already got an answer in the Minnesota forum. It's best not to crosspost these types of questions. Since the ARMER system is still under construction, it's likely that control channels will change from time to time. I would program all the frequencies listed for a site, so the radio can lock on the right frequency when a control channel changes.
Go back to the Minnesota forum (remember what I said about crossposting?) and ask the question there. People in Minnesota that are monitoring the ARMER can give you much better answers than most of us. It's possible the system is still testing, hence you're only getting an open carrier on the control frequency.
I've programmed in all the frequencies besides the control channel and tuned all them up one step and turned off the delay, (858.9000 to 852.90625). Otherwise it would sound garbled and unintelligible. I can only hear it clearly when I'm about 5 to 6 miles from my nearest simulcast tower (I live 9 miles away). In certain places in my house I can hear them clearly. This was just to let everyone know I don't have a problem listening anymore.
From RR WikiI have a Radio Shack PRO 2096 and after all of the years on analog,they switched to multi path Simulcast and now all I get is garbled mush with a few clear words once in awhile. Does anyone have any suggestions?
I have not messed with the Firmware, or anything. I did invest in the cable and got a disc with it for something similar to WIN products, so I am not getting anywhere. I have two other identical radios to
get tuned in.Please help me if you can..
From RR Wiki
"Simulcast refers to the process of transmitting the same signal from multiple sites on the same frequency at the same time."
Pointing a directional antenna at nearest tower may help.
