Pro- 96 programming help
bono_328
bono, arkansas
I picked up a pro-96 today from a guy real cheap it didnot come with a book i was wondering if someone could walk me throught the programming of the awin system into this. I want Jonesboro and Nea are ( if that helps). I am not famlier at all with how to programm the new system. or how to go bout downloading the file from this site. i would like to learn both ways. thanks for all the help ill be getting the programming cable later today and will upgrade my membership.
bono_328
bono, arkansas
learned part of it
which setting works the best mo, ed, am, fm,ct,dc,????????????? and what is the differences?
bono_328
bono, arkansas
ok took it up to radioshack they programmed it with all the jonesboro staions and troop c stuff. works great i learned alot bout programmig it from there. is there anyone else in the NEA area tht has anny suggestions of some channels to put in . I want to listen to Arkansas childrens helicoptor and all others medical helicoptors in the area such as air evac if any one could help me with that. i really wanna thank all of yall for ur help with getting me started.
Tim-in-TX
Pearland TX
Two things that will make a world of difference to you and your new scanner:
1. Purchase Win96 from Starrsoft ( PRO-96 Software - Win96 - Data Management Software for the RadioShack PRO-96 and PRO-2096 Digital Trunking Scanners ) This is a program that will be of great help to you in current and future programming.
2. Become a premium member here at RR. Besides all the wonderful perks you get for subscribing, you will also be able to use Win96 to directly download whatever frequencies you want from Radio Reference.
Trust me, these are WELL worth the money!!!
Happy Scanning!!!!!
INDY72
Indianapolis, IN
If you get Win96, I can make a .p96 file of any AWIN stuff you want, and you can load it with a snap. Be sure you get the interface cable. I can also set up conventional stuff for your area and have you listening to everything there is to hear.
safetyobc
South Arkansas
Win96 (or anything from starrsoft.com) is great software for scanners! Definitely pick that up even if it is just used to back up your scanner.
poppafred
North Central Texas
You can get a PDF file of the manual here:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000526_PM_EN.pdf
