PRO-96 ?
tonya
Bratenahl Ohio
I'm guessing that if you cannot program a LTR system in a P-95 the same is true for the P-96. Am i correct?
FPO703
Planet Earth
You are correct. The only PRO series that I can think of that will work with LTR systems are the PRO-92 & PRO-2067. There may be others, though.
Al42
Long Island, NY, USA
The Pro97 and Pro2051 also work with LTR systems, according to the manuals. (I've never owned either one.)
D
DaveNF2G
Guest
I can confirm that for the PRO-97. It is apparently a Uniden-made scanner, though, because it requires LTR repeaters to be entered into the correct memory slots to match their channel numbers, just like the BC-### scanners that do LTR.
loumaag
Silent Key - Aug 2014
Katy, TX
Whereas it is true that the Pro-97 requires the LCN's to be properly positioned, it is not a Uniden built scanner. It is a GRE device; the FCC ID is ADV2000527.
ADV=GRE
Joseph11
ADV=GRE
The PRO-92 doesn't require LTR to be programmed in LCN order, it would be odd for the PRO-97 to.
INDY72
Indianapolis, IN
They made the 97 with the LCN order to make it more accurate in tracking the LTR systems.
MacombMonitor
Yes, the PRO-2051 does LTR. It is an enhanced version of the Uniden BCT8.
if its asking for the lcn, it sounds like the way uniden does it with the bc 246 t and maybe the bcd 396 t.
bill simpson
n1jbs
loumaag
Katy, TX
Not really. The 396T (and I assume the 246T) don't work the same way as the Pro-97. THe Pro-97 has banks and numbered positions in the banks. LCN's must be assigned to the proper slot in the bank to correspond with the LCN position of the frequency. The dynamic memory radios of Uniden (396T & 246T) don't work that way, you simply put in the frequency and then it asks you what LCN is assigned to the frequency. This allows you to put the freq's in any order and assign the LCN's in any order. Of course they must match the system LCN's. :D
