Pro 97 Programming Cable
dm1313
Spiro, OK
I just bought a Pro 97 off of eBay and doing a lot of research until it gets here.
I've always programmed my scanners manually, but considering trying either Win97 or Scancat-Lite-Plus. Any major differences between these programs? Also,I'm wondering which cable to use to program the 97 with? I have seen references to using either the RS #20-289 or #20-047 and also other cables from sources other than Radio Shack.
Thanks,
Martin
KE5BCP
Analog Man
Lewisville, Texas
Thanks,
Martin
The 20-289 is for serial ports.
The 20-047 is for USB ports.
The over-all consensus is that Win97 is FAR superior to the other program you suggested.
n2mdk
Ames, IA
Thanks,
Martin
Yes Win97 actually works, ScanCat-Lite-Plus is more than likely to mess up what you try to program into the scanner, if it doesn't crash your computer first.
lowboy654
DB Admin Member
Northwest, WA
Thanks,
Martin
I own scancat and win 97,96 and your best bet is to run as fast as you can from scancat to win 97 I see that I am the 1 St to reply a the programing software and I am sure that everyone that has used both will agree with me. save your money and use Don Starrs win 97
dm1313
Spiro, OK
Re: 97 Programming Cable
Thanks for the quick replies...looks like Win97 is the way to go...I've had all the computer crashes I need.
NoRide
New York
Another vote for Win97. I also prefer a USB cable. Enjoy your new scanner when it arrives.
