It sounds like you downloaded the Free Client. Download ProScan.looking at the top categories ! it only shows OPTIONS VIEW SUPPORT ??????? what gives
Yes I did download the incorrect software. I now have the latest upgrade the 19.4 , all good thanks for your help. Angelo KO4IPVIt sounds like you downloaded the Free Client. Download ProScan.
Yes, your scanner is listed along with all the (many) other models that Proscan 19.4 for Win 10 supports. Look at the list on the Proscan website right under the "ProScan" heading where you downloaded the software from:okay so i downloaded a another version of proscan !!! the 19.4 version ,still wondering if i choose the correct one , I am running Windows 10 , can someone please advise me ? my scaner is a BCD325p2
Thankyou, for that information just needed to confirm that.Yes, your scanner is listed along with all the (many) other models that Proscan 19.4 for Win 10 supports. Look at the list on the Proscan website right under the "ProScan" heading where you downloaded the software from:
ProScan
Computer Aided Scanning Software for the Uniden BC125AT BC250D BC296D BC346XT BC346XTC BC780XLT BC785D BC796D BCD160DN BCD260DN BCD325P2 BCD396T BCD396XT BCD436HP BCD536HP BCD996P2 BCD996T BCD996XT BCT15 BCT15X BR330T SDS100 SDS100E SDS200 SDS200E UBC125XLT UBC126AT UBCD3600XLT UBCD436PT...www.proscan.org
thanks for your recent help , however now my problem is this , I am attempting to fill my database file , after click on database , then ( new) I see rows of info ! How do I transfer that info into my database file ???? I am trying to follow the info in the proscan 19.4 manual but it is ver ambiguous. Please explain would appreciate that very much. Also after completing that task , then how to download into my scanner ( BCD325p2)It sounds like you downloaded the Free Client. Download ProScan.
You shouldn't see any rows after clicking on New unless an older scanner type is selected such as a 780, 785, and other non DMA scanner types.thanks for your recent help , however now my problem is this , I am attempting to fill my database file , after click on database , then ( new) I see rows of info ! How do I transfer that info into my database file ???? I am trying to follow the info in the proscan 19.4 manual but it is ver ambiguous. Please explain would appreciate that very much. Also after completing that task , then how to download into my scanner ( BCD325p2)
Very good now after clicking upload to scanner I see a box popped up in the middle of my page and says upload to scanner at the top. in that box there aresome selections do I select any of the options or just click upload at bottom of the box ???Click on Upload to Scanner to load the file into the scanner.
After you click on New then type in a name for the new file then click Save. At this point, you want to add systems. Since you are a premium subscriber, you can import from the RRDB. Go to the Database menu then click on Import then RadioReference Web.. See if you can take it from there.Also when I click on database and then New ! What is in those Text Documents listed ! Is it possible to view before I download into my radio?
A little clarification: You Upload to Scanner to write files from ProScan into the scanner. You Download from Scanner to read files in the scanner and load into ProScan.Is it possible to view before I download into my radio?
Yes , okay I guess what my question should be is can I download from scanner to the software ? So I can see it in front of me , then edit and then upload to scanner?A little clarification: You Upload to Scanner to write files from ProScan into the scanner. You Download from Scanner to read files in the scanner and load into ProScan.
