mikes951
Hi just got my pro197 all programed now I need a outside antenna and coax like 50' what does someone recommend for me? Thanks
Hi,I just have the original antenna came with it I want to up grade to an outside antenna and the right cable for listening all my county.thanksWhy not give us some info on who you're having trouble monitoring so we can get eyes on the database to see if the Pro 197 is the right tool for the job & thus make an informed recommendation for you?
Just want to listen to police and aircareHi,I just have the original antenna came with it I want to up grade to an outside antenna and the right cable for listening all my county.thanks
Understood but I'd rather not make a blind recommendation. Please confirm county & agencies of interest when you canHi,I just have the original antenna came with it I want to up grade to an outside antenna and the right cable for listening all my county.thanks
| Ohio MARCS-IP: Multi-Agency Radio Communications | All Clermont County agencies use the Ohio MARCS-IP system |
I had a discone. I have a Omni X now, it has no issues with the other stuff besides the 700-800 stuff at all. Local airport is 120's an forestry is 150's. I can hear that stuff just fine. I can get the Ft Myers airport 30 plus away as well.If an outdoor antenna is What you want, get a discone. Wide band coverage. Get LMR 400 coax. A Omni X is more tuned to police and has gain to help. Depends how much you want to spend. Just make sure it’s above your roof top.
Yes and Browncounty toois that the system that you are trying to hear ?
Ohio MARCS-IP: Multi-Agency Radio Communications All Clermont County agencies use the Ohio MARCS-IP system
Thanks for info so the lmr240 coax would be the best or RG6 coax about the same? Any discone antenna would work fine or recommend me something better.thanksI got a 197 with RG8 and a 1/4 wave ground plane at 15' and could hear some local VHF. I then got some LMR400 with a Comet DP9 at 30' and went from a local area to half the state! I was very frustrated though because agencies moved to the 700-800 Mhz and my expensive VHF/UHF antenna was not good in that range. I am rural so I got a 800 Yagi and it works great. The most important thing is COAX! You can easily loose half your signal with the wrong type. It must be foil shielded. I love my LMR400 but the flexible LMR240 would be easier to work with. Right now I am testing a 15 element yagi with RG6 and can pick up a system 60 miles away. Also the 197 will not work in a simulcast area.
Would you use Rg58 cable 50' or RG6 cable are there alot of different?just got a discone antenna for pro197I got a 197 with RG8 and a 1/4 wave ground plane at 15' and could hear some local VHF. I then got some LMR400 with a Comet DP9 at 30' and went from a local area to half the state! I was very frustrated though because agencies moved to the 700-800 Mhz and my expensive VHF/UHF antenna was not good in that range. I am rural so I got a 800 Yagi and it works great. The most important thing is COAX! You can easily loose half your signal with the wrong type. It must be foil shielded. I love my LMR400 but the flexible LMR240 would be easier to work with. Right now I am testing a 15 element yagi with RG6 and can pick up a system 60 miles away. Also the 197 will not work in a simulcast area.
