Pro2096
Rcarde40
Hey guys I’m in Ontario, Canada and I’m having some issues with my 2096 base. I put in all the tower freqs reds first, then blue, then the left over blacks just in case, why not. So I’m picking up some type of ambulance it’s coming up as Id like 35588 and on one channel.
It’s just static and weird sounds, lol not tone paging I know that sound. And it’s the red channel so the primary. But the other channnels in black are picking up with id numbers.
Also, if I put it on scan it’s scanning the banks but not picking anything up. I manually added the above ones and it worked out. But the programmed ones aren’t working. Anything???? Again in Central Ontario Canada
Rcarde40
I’m not even sure. I hit program, put in the numbers then hit mode to MO
And it started getting really staticy and making the noises so I locked it out and then the other channels started picking up in MO as well in the right corner.
Rcarde40
Here on RR.
They are Bell fleetnet. So digital
torontokris
Toronto Canada
Put in the numbers then hit mode to MO
And it started getting really staticie and making the noises so I locked it out and then the other channels started picking up in MO as well in the right corner
It sounds like you programmed as conventional and its scanning the channels conventionally one at a time - when it hits the control channel you are hearing the CC noise.
Page 56 Programming trunked system
Forts
Ontario, Canada
You also need to set the trunking system to use a custom VHF bandplan....
Rcarde40
I can enter the Custom VHF band plan, but there’s 3.
Which would I use?
Rcarde40
No idea at all
So thanks for all the help guys I give up
Will be posting it for sale pro2096 and a hustler antenna
