Problem Here
hpycmpr
Los Angeles County, CA
I seem to have managed to disassociate my talk groups from several of my TSYS systems in Win 500. All the info is still in the ALL OBJECTS list and the radios (500 & 600) haven't been affected. But nothing is listed under the TSYS talk groups. How do I assign the TG's to their appropriate TSYS?
And how did I likely accomplish this feat to begin with?
Steve
Highpockets
Toms River, New Jersey
Steve
Here is a Guide for using Win500, maybe it will give you some ideas on solving your problem.
http://utahradio.org/mediawiki/index.php/WIN500
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Hi Steve & Steve,
If the scanners are ok and with cable plugged into either, use Ctrl + U. After upload is finished, check to see if you have Scanlist assigned under each TSYS. If so, save file either using a new name or save to same file by replacing the file under suspicion.
hpycmpr
Thanks Steve and Frank. The Utah Radio sort of helped with the concept. The problem turned out to be clicking on the empty table of TG's on the ID box. It doesn't indicate that anything happened - no color change or anything. I then clicked on the New Item At End and it worked. Then copy and paste. I'm back!!! I was faked out by the no obvious change when clicking on the ID box. Another learning experience!
Thanks again.
Steve
