Hey guys can we please stay on topic with this thread. I would really like to get this situation for all of is experiencing problems with our radios.
Sent from my SM-N960U using Tapatalk
Horsepuckey. I transmit 50-100 watts PEP VHF (2m) on my Icom 746 Pro quite often (usually everyday) and my SDS100 sits on a desk stand 3-ft away and is not affected in the least. No problems whatsoever.
I'm assuming your radios are 3 ft. away from each other (transceiver/scanner) in a fixed station and not from a TX antenna, correct?
I've had radios side/side and stacked for years with no issues. I was referring to TX antenna to SDS100 RX antenna distance as typically mounted in vehicles.
has anyone on this thread had low signal on analog UHF /VHF/800 (compared to the 436) and tinny audio on analog on their SDS100? I sent my SDS100 back for a refund, but would like to re-purchase one if these issues are resolved. I loved the p25 digital system performance.
Honestly, depending on what they are being used for, transistors have a fairly high failure rate compared to other components in any electronic. One of the main functions of them is to amplify current, and any shorts in the system can cause a lot of stress on them. We haven't had a ton of SDS100s go through our repair department, and those are not commonly the reason they have.
It is possible it is a manufacturing defect; anyone who has worked in a factory can tell you mistakes can happen. it's the job of ISO compliance to minimize that, and it's a big part of why we have warranties. A transistor is likely to fail if any of the components in the circuit have a problem, so while they may pop up as a replaced part often, it can be caused by any number of failures. We track all of these failures and if there was any sort of common defect, we remedy them, but it does not seem to be the case here.
Most likely it's not anything you are doing with your unit, you can help ensure the health of your scanner by avoiding dropping it, making sure it has good air flow around it, and as hard as it may be, sometimes it's good to give them a bit of a rest.
I'm a bit confused by the last recommendation "...sometimes it's good to give them a bit of a rest." Does that mean that we should only use our SDS100s for a limited amount of hours per day? I have never owned a scanner, and I have owned many (beginning in the 70's), that required giving them a rest. In fact, my BCD536 and PSR800 (which is now my daily portable until I get my SDS100 back from repair) have been operating 24 hours per day for years.
Hopefully the SDS100 is repaired correctly, quickly and will not be on any sort of 'minutes restriction' like an injured professional athlete.
To Uniden support: please advise us on here when there is a firmware update for the sds100
Any electronic that is ran constantly is more prone to component failure. This is just a general recommendation, it is not a requirement specific to the SDS100, I simply meant that powering them off here and there will extend their life, and that applies to all scanners or electronics in general.
Agreed. Thermal cycling is a slow killer. Not much of it in typical battery powered receivers, although the SDS100 breaks that rule.Electronics held at a constant temperature (like always on) will survive better than thermal cycling (i.e. on and off.) Also true for tube equipment.
The major current draws (and heat sources) turn off.When you turn off your TV it doesn't really turn completely off - it goes into stand-by mode. Same with many high-end audio components.
Would you please back this up with some science? I think your proposition is rubbish.
More directly to the point about "taking a break" with batteries being beneficial..
Probably only applies to batteries that has heat as its worse enemy.
