BCD436HP/BCD536HP: Problem writing SD card
w1dbc
townsend ma
hello, im having trouble with my 436. I just got it back from Uniden and when I go to write a new fav list, the sd card file will not show up. im in mass storage and its plugged in but the sd just doesn't show up and I just called Uniden and they said to try here for help. anyone can help????
Markscan
New Jersey
Make sure the box show all drives is checked. Sometimes that is the problem.
JoeBearcat
Inactive member
Uniden Representative
Did you put the card in after it came back or was it shipped with the card?
If the former, is it a new card?
w1dbc
townsend ma
the original card was in the 436 when I got it back and it has old programming which works just won't program, plus I have a brand new sd card that also does not work
JoeBearcat
Inactive member
Try the brand new card (at least as a diagnostic test).
You will have to CLEAR USER DATA first before it becomes visible to Sentinel. You may want to make sure it is formatted as FAT32 first.
It is possible your PC is seeing the existing card as 'read-only'.
w1dbc
townsend ma
tried formatting, with new sd now getting sd card file error on 436. I formatted it on sd card adapter
JoeBearcat
Inactive member
I would prefer to discuss it here to help others.
Is it formatted as FAT32? What is the size of the card? Did you CLEAR USER DATA afterward?
w1dbc
townsend ma
fat32? not sure. original card is 4gb, new one is 128 I believe. when I put the new card in and plug it in the sd file error comes up and can't do anything including powering it on
JoeBearcat
Inactive member
'What he said....'
128GB may work but it will HAVE to be formatted as FAT32. Cards that large usually do not come properly formatted.
JoeBearcat
Inactive member
You have to use a Micro SD card formatter. I will try to find a link unless someone else posts one first
JoeBearcat
Inactive member
Physical adapter? No. We are talking about software.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
