Program Scanning in F-3061T
KE7HIM
Hello, My first post on the Forum. I'm failing to understand how to program scanning into my 3061t. It is analog, running software ver. 1.7.
Tried following tips from a 2002 post and the limited info in the factory manual. Anyone point me to more detailed/explanatory sources or provide an example file demonstrating different scanning options. I'd like to designate a current channel as priority while scanning others in the same zone. Been using it in SAR and now have greater duties the make scanning more important to me.
thanks
Glen
KE7HIM
jeepsandradios
East of the Mississippi
Scan is simple. Make sure you select the proper scan list in the memory section
Then under key and display make sure you select a Scan A or B button. When tuning scan on puish and hold first time to set the scan list. Then it should scan the channels
KE7HIM
Thank you! I set a zone as scan list 1 and another as scan list 2 , set P0 as ScanB. set several scan types to check behavior. Now exploring scanning.
73
KE7HIM
