programming assistance SDS 100 using uniden sentinel
Kentucky
if someone can see what im doing wrong and tell me that would be great. only getting a few FD calls and then nothing. no pd nothing. will send my list
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
FYI your county services now operate on the trunked radio system linked below. You'll only be able to monitor mode "T" talkgroups on said TRS, mode "TE" talkgroups are fully encrypted and cannot be monitored
Do you have the paid upgrade to monitor TRBO (DmR)
Check the MODE Column.
To receive DMR transmissions, yes.
Where are you seeing DMR, Doc?
Kentucky
yeah i know, looked before ordering boone isnt on a encrypted lock dont think kenton is. for whatever reason it wont pick up at all
RMason
Colorado / Mississippi
It looks like you are programming this P25 system:
You will probably want to enable the following service types for FD and PD in Kenton. (You do not have the Tac service types enabled). See the TAG column.
Emergency Ops​
Fire Dispatch​
Fire-Tac​
Fire-Talk​
Interop​
Law Dispatch​
Law Tac​
Law Talk​
Whiskey3JMC
Simulcastylvania
Whiskey3JMC
Simulcastylvania
You only had a law dispatch & public works talkgroup & nothing else programmed in which explains why you weren't able to hear much (with ID search turned off) Try importing the attached
  • kenton county 1.zip
