Programming GRE 500/600 for STARS
edyeary
Tenn
Can someone walk me through the programming steps for the PSR 500/600 and the Va. STARS system in general and specifically for Dist. 4 ?
Highpockets
Toms River, New Jersey
You should have the programming cable and your a Premium Subscriber so, if you pick up this software:
Win500: PSR-500, PSR-600, PRO-106, PRO-197, PSR-310, PSR-410 Scanner Software for Data Management, Monitoring, and Control
And use this Guide, you'll be able to import from RR into the software and upload the info to your scanner.
WIN500 - UtahRadio
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Welcome to RR
Where are you located in Div 4? I can't determine a tower to use. Need Control Chanel info.
edyeary
Tenn
I'm in the lower portion. I listen to the Lee Co. S.O. and would be listening to Jonesville on the state police freqs. I still hear traffic on 159.165 but not as much as before.
fmon
Eclipse, Virginia
If you download Steve's suggestion (Win500) use Web Import. Due to no controls listed uncheck the default box labeled CC only. Then select Sites 2-0042 and 2-0043 which should give you 15 channels on bottom of Win500 import dialog.. Then check at least the 6 talkgroups from Virginia State Police Div 4. You can also check other agencies if desired such as ABC. Games & Inland Fishing etc.
DON''T forget to select a Scanlist in dialog after clicking IMPORT THIS SYSTEM bar.
edyeary
Tenn
Thanks. I'm using Butel software. I'll see what I can do.
fmon
Eclipse, Virginia
Suggest these two towers as checked and the several Talkgroups as checked. Then check a scanlist in Scanlist tab. Then click Green Import bar.
edyeary
Tenn
I've got the freqs. programmed in and the tower and talk groups I want. Will let you know how it goes.
