Programming Issue with G4
BabaDude77
Connecticut
Been having an issue with programming my G4, I am using a windows 7 laptop (same computer I have been using to program pager since I got it about a month ago) am running most up to date firmware 1.33 and using most up to date PPS (also when downloading PPS it also added most up to date driver) When I plug in pager it connects to PPS and pager shows PC Connected. I click program and the PPS just spins on preparing programming data usually takes about 5-10 mins now it won’t program new data at all, let it sit for about 40 mins nothing. CP has about 25 zones and 4-5 systems also about 300 unit IDs. Couldn’t seem to find any fixes on here or online just wanted to check before I rolled back to a previous CP and had to re enter zones.
Enjoi19
Ontario, Canada
I had this issue when I imported multiple talkgroups from RR that had the same TGID, but on different systems.
I deleted one zone / system at a time at a time and their associated talkgroups until I found the conflicting one that was hanging up the upload.
BabaDude77
Connecticut
I did read that earlier but this is the first it’s given me any trouble on it and I do have multiple TGPs that are the same number on different systems. Seems dumb though what should I do if I want both talkgroups on the different systems ?
Enjoi19
Ontario, Canada
I haven't really dug into it further and ended up just removing that system from my programming and adding it to a separate file that I upload before I head to that area. Not really convenient at all. Here was the thread I had about it with the answers too:
BabaDude77
Connecticut
I’m wondering if I put a zero before the TG number example of a talkgroup of 100 and making it 0100 in the CPS would that fix it ?
No because the pager would be looking for 0100 rather than 100 and you'd never hear the traffic. The fix is in the beta PPS.
BabaDude77
Connecticut
So a short update , today tried to delete duplicate TGIDs and found it was going to be way too much work, not as simple as deleting the TG from the master list turns out you have to delete them from each zone and knob position first. Really didn’t want to start over from scratch not with 3 states worth of stuff, so I said screw it and plugged it in and went for the update thinking I’ll let it sit all day if I need to. Connected fine, showed PC connected on unit and same prompt screen just spun on CPS. Finally 1 hr and 40mins later the pager screen switched to programming and a few seconds later showed programming complete. A message popped up in the CPS saying programming failed due to timeout. Discouraged I unplugged the pager it rebooted and come to find out all new zones knob positions and talkgroups were added no problem. I guess I just need to leave myself around 2 hours each time I have to update the pager (which shouldn’t be too often I hope)
