WSEY364
Just realized that the original post is almost a year old now. Kinda looks like that my post is not all that timely and relevant any longer. Sorry for the untimely post.
Not untimely at all. I just purchased the UHF 100Watt version. I have poked around and read for a while on this radio and have what is more than likely a dumb question; These radios can be programmed to use CTCSS, right?
N4KVL
ÆS 8675309
South FL
Yes.
In "Motorola" terms, CTCSS is referred to as "PL" for "Private Line". Just their nomenclature for the Continuous Tone Coded Squelch System.
DPL = Digital Private Line.
All the same, just different names.
nokones
Sun City West, AZ
It wont work on W10. Also doesn't like USB DB9 adapters. This is OLD stuff. I use a W95 machine with native 9 pin and reliably program our SAR radios.
I use an USB to Serial Adapter cable with a Prolific driver to the RIB and a Bluemax 49er Cable from the RIB to the Radio, on my XP 32-Bit Windows computer.
WSEY364
@mmckenna @N4KVL Thank you Gentlemen. I ended up installing Virtual Box then using Windows Vista 32 Bit with a Bluemax49er cable. No issues programming now.
My 25hz attenuator has apparently been tuned wrong in the Tuner Software. That one is more daunting for my skill level. Having issues with the radio picking up weaker signals. Can't get the squelch settings just right. I'll keep plugging away.
nokones
Sun City West, AZ
Why would you need to install a virtual box on a Vista 32-bit Operating system to run the MCS2000 CPS? You should have been able to run the CPS straight on the Vista 32-bit system and program the radio. Vista was nothing more than an enhanced XP operating system with some security fixes. I had no issues with my Vista using the MCS2000 CPS
