Programming ws 1065
once i have figured a watch list from radioreference, how is it programmed into my scanner via usb cable? is there any additional software i need to purchase?
Yes, you need programming software. Here are good recommendations from @tvengr
Whiskey3JMC
Simulcastylvania, TE
Welcome to the RR forums. Why not tell us where you're from and/or the agencies you intend on monitoring so we can verify the WS1065 is the right tool for the job
Just bought a WS1065 scanner, tried to program manually but beyond my pay grade, I have set up a radioreference account and have set up a watch list for collier county florida. Is there anything else i need to do, such as programming software before i plug in the usb cable? thank you folks for any tips.
tvengr
Well Known Member
Baltimore County, MD
Your scanner should be OK for Collier County. You will not be able to receive the Sheriff or Naples PD. They are fully encrypted and cannot be received by any scanner. Although the P25 system is Phase 2 capable, all of the talkgroups are currently Phase 1 which your scanner can receive. It would help to know your city. There are 8 sites and your location is needed to determine the best site or sites. As Whiskey3JMC mentioned, you may experience simulcast distortion depending upon your location.
iMONITOR
Silent Key
S.E. Michigan
tvengr
Well Known Member
The D in the Mode column shows Marco Island PD is clear to receive. If it were DE, it would be fully encrypted.
DEC HEX Mode Alpha Tag Description Tag
17001 4269 D Marco Island PD1 Police Law Dispatch
You can also use Butel ARC500 software which also has a free trial. I use ARC500 Basic.
