ProScan Limitations
VK3YMML
VK3VSN / VicScan Forum Owner
Melbourne, Victoria
Hi
I have a UBCD996P2 and wish to upload CSE Orion Network - Connect Plus and Connect Max however there are a large amount of UID's and Channels and seem to have no issue with Sentinal for my 436-PT.
However, when using ProScan I get the following error and wondering there are any workarounds
CT
Those are limits in the Scanner - not in the software.
996P2 Specifications:
Limits
  • Channels: 25,000 maximum
  • Systems: 500 maximum
  • Groups per system: 20 maximum
  • Talkgroups per trunked system: 500 maximum
  • Channels per conventional system: 1000 maximum
  • Scan Rate: 100 channels per second (conventional mode)
  • Search Rate: 300 steps per second (on 5 kHz steps)
  • System Quick Key range: 0-99
  • Group Quick Key range: 0-9
  • Custom Search Ranges: 10
  • Startup Keys: 10
  • System Number Tagging: 999
  • Channel Number Tagging: 999
  • Preprogrammed Service Search Bands: 12
  • Band Scope Span Range: 0.2 MHz To 500 MHz
  • Band Scope Step: 5 kHz To 100 kHz
See here:
Uniden Bearcat BCD996P2 Police Scanner | Scanner Master
