I just opened up ProScan and was prompted to download the new version (12.9) which included NXDN support. Uploaded my 536HP and there it is...all my NXDN programming. Sentinel not far behind?
Doesn't even detect my scanner via usb to usb. Didn't want to do the wifi route. ARC and Sentinel have always been plug and play no problem. Just thought I'd try ProScan from what I've been reading in this thread until the others are NXDN updated. Manual states you can use the software via scanner front usb to computer usb.
I use wifi for programming all the time.
Has anyone ever had ProScan work on 536 via front usb to computer usb? Have never been able to get this software to work with x36 scanners.
Never mind my mistake need to learn how to read. Sorry for the confusion.Really ? never seen support. How do you get it to even see the SD?
12.11 is out, there was an channel number issue
What was the channel number issue?
It was downloading them as 1,2,3,4,5,6 etc
See the other thread
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
Which thread might that be? I'm running 12.10 without issues.
On ver. 12.10 Importing from RRDB NXDN Trunk systems, was using the LCN value. Ver. 12.11 uses the CH ID param.
Are there any detailed instructions or videos on importing from RRDB in ProScan? Can't find anything on the internet or clear details in the manual to do this procedure. The manual states that ProScan can import from RRDB but does not give details on how. Makes a great virtual on computer and can project as many scanners as computer can handle.
