Proscan Web Server on iOS
fdnyfish
Barnesville, PA
I set up the Web Server in proscan with my SDS100 and I can see the webpage on my PC. I am unable to see the webpage on my iphone that is connected to the same wifi network as my PC. Is this something that should work on my iPhone and iPad via a browser?
ProScan
Software Provider
Ontario, Calif.
It works here on a iPhone using Safari and local and outside IP addresses.
Are you using the local or outside address. If outside, did you set up the Router Port Forwarding?
eaf1956
Evansville, IN
I can never see mine while on the same network. I can only see the web server from outside the network.
I guess I need to clarify my statement: While on the same network I can only see the web server using the 192.168.1.x address.
Just the way my router works as I tried this on other networks and it didn't work that way.
