Protests / Riots
trimmerj
Pasadena, MD
I'm expecting things to be heating up in Baltimore this wknd. Since the city's last radio upgrade, I haven't been able to copy any traffic on my bc796d. Not sure if signal is too weak in the Dena. How bout National Guard, are they still using the VHF Radios ?
ScubaJungle
West Central Florida
Do you have the digital card for the bc796d? If so, you should be able to copy them according to the db (P25 phase I, nothing says enc.)
If not, then its because you are trying to listen to P25 on an analog-only scanner (without the digital card)
maus92
The OP
Let's hope not. It would be a tragedy for innocent residents to have their badly needed infrastructure destroyed. Peaceful protesters must to be vigilant to prevent their demonstration from getting compromised by agitators / agents from outside the area / country. The MNG uses FIRST, mostly ENC.
tvengr
Well Known Member
Baltimore County, MD
What programming software are you using? My 796 works better on the Baltimore system than the newer scanners, except for SDS.
tvengr
Well Known Member
Give this file a try. Banks as follows:
1. Balt Co Fire S
2. Balt Co Fire N
3. Balt City Fire
4. Balt Co Police S
5. Balt Co Police N
6. Balt City Police
Save the attached zipped file to your computer and extract. Open the extracted file with ARC250.
trimmerj
Pasadena, MD
1. Balt Co Fire S
2. Balt Co Fire N
3. Balt City Fire
4. Balt Co Police S
5. Balt Co Police N
6. Balt City Police
trimmerj
Pasadena, MD
1. Balt Co Fire S
2. Balt Co Fire N
3. Balt City Fire
4. Balt Co Police S
5. Balt Co Police N
6. Balt City Police
The attachment vanished. Could I get you to re-up?
I see the Balt City chopper N453F up now circling the downtown area
based out of Martin State airport.
Also the Camera plane Cessna 207 N73266 circling from in and outside City.
TV Chopper up N713TV R-44 type. Heard some coms on 450.3875 NFM air and ground but not sure
if Baltimore or Philadelphia. Also TV 455.2125 active but unreadable from here.
maus92
The OP
There were peaceful protesters blocking Pratt Street. Seems to have cleared up. Seven unrelated shootings and three deaths this weekend thusfar.
tvengr
Well Known Member
1. Balt Co Fire S
2. Balt Co Fire N
3. Balt City Fire
4. Balt Co Police S
5. Balt Co Police N
6. Balt City Police
  • Baltimore City and County.zip
That is WJZ TV.
Thanks.. Was funny coms on 450.3875 as Ground TV Director said earlier this afternoon to chopper "We see a Police vehicle on fire
on CNN.. "Can you see any smoke"? Negative reply
Comes back a few minutes later and says, Never mind wrong City on CNN..
2005 local No TV Choppers showing over City but Balt County Helo N804CP hovering at City/Balt County border.
trimmerj
Pasadena, MD
Stupid Question....Do I need to update the firmware on the 796D (Rebanding) to monitor Baltimore City? Will I still be able to listen to Anne Arundel after doing so ?
maus92
The OP
Anne Arundel is rebanded, so if you are receiving them, you should be able to receive BC.
firebal
Baltimore, MD
MSP Golden Ring sounds like they are helping city units. Confirmed by WBAL.
tvengr
Well Known Member
I don't see any 851, 852, or 853 MHz frequencies on the Anne Arundel system. The standard bandplan is fine. The Howard Co Motorola system was rebanded. The latest firmware for the 796 is v3_60. You can check it by holding 2, 4, and 9 while turning on the scanner. Baltimore City works OK without a custom bandplan.
maus92
The OP
Perhaps I confused their Nextel frequency swap as "rebanding." The new system will have 4 channels in the 851-853 range.Screen Shot 2020-05-31 at 12.12.36 AM.png
