PSR-500 Scan Lists Flashing
wphm449
Temecula, CA
After updating the scanner's firmware to 1.8, I noticed that after scanning from pausing an object, random scan list numbers flash. There is no rime or reason to it. There are active, unlocked objects in the scanlists that are flashing. Anyone else expieriencing this issue or know how to solve it.
lehigh4me
Lehigh, Iowa
I have been having the same issue, but haven't figured out why it is doing it.
rgchristy
Delco, PA
It usually means that you have an active scanlist that has no objects in it. You might want to reassign the objects in the flashing scanlist to another scan list, check to see if the scanlist is still flashing (it should be) and then assign the original objects or other objects back to the flashing scanlist and see what happens. Sometimes objects get corrupted and after reassigning them, they are ok.
Hope this helps,
Rich C
