jaaredmond
I'm getting a PA low beep on my vhf quantar. When I went to check it out, it displays the PA low when keyed. The service manual says if the unit isn't recieving enough DC voltage that this will happen. I checked that batteries and the charger was showing around 28.5 volts. Which is above the required dcv.
I also changed the battery setting to "NONE" so the unit doesn't think there is a battey, and still get the same PA low LED and the 2 beeps.
Is there a way to do a reset? Or can anyone shed some light on what may be going on? This is a fairly new repeater that has only been in service a few months.
Thanks,
James
Thanks,
James
