Rabbit ears for 2 meter?
majoco
Stirrer
New Zealand
A quarter-wave for each element (about 19") is the only one that you could possibly make out of bunny's ears as anything other than odd multiples of a quarter-wave won't give you a 75ohm impedance.Three-quarters would be OK for impedance but you won't get any better signal in or out.
LtDoc
Oklahoma
What length for those 'ears'? A 1/2 wave center fed antenna is about 70 - 75 ohms if it's a 'straight' antenna. If you tilt those 'ears' just a bit, make the angle between them less than 180 degrees, the input impedance starts going down to closer to 50 ohms. So, if you have a meter, try that 'angle' thing to drop the SWR. There's no real benefit to using a full wave center fed doublet. First, the input impedance isn't going to be even close to 50 ohms. Then the radiation pattern isn't going to be a 'usable'/predictable as with a 1/2 wave. Wanna try it? Have at it, see what you think.
- 'Doc
joseph2020
CO. US
Thank you for the replies. This antenna theory is kicking my butt. What is the eaiest and cheapest way to learn more about antennas and how they work. I know the basics, but even a simple project like this needs more than the basics, therefore the questions.
What about element thickness (question #2). Does it matter much in this situation? thanks again.
LtDoc
Oklahoma
Element thickness may make a very slight difference in the final length, but not much, and I seriously doubt if you'd ever need worry about it.
- 'Doc
smokeybehr
CenCal
The recommendation to make a J-pole out of twin-lead is about the best idea. I've made several of them for 2M and 220mhz. You can also make one for 440, but the tolerances are a LOT tighter, and it's easier to make one of those out of brazing rod or 10-12ga solid copper stripped out of Romex.
If you have pipe soldering skills, then you can take a try at a "Copper Cactus" which is a J-pole made out of copper water pipe for 2M. I made a J-pole out of brass tubing for 440, and it works spectacularly.
joseph2020
CO. US
smokeybehr, thanks for your informative reply. I wanted to build the "ears" antenna because it was cheap (very important right now), and Ithought it would be a "fun" and easy project, besides, I love using old technology.
I also just built a twin lead J pole from these plans: The Twinlead J-Pole Antenna. I had my friend do the soldering (she is a professional) and should be picking that up and doing some field testing some time this weekend.
If it works, I might try the 10 or 12 ga stripped romex next. Do you think that would be worthwhile improvement from the twin lead J? Thanks again.
LtDoc
Oklahoma
I seriously doubt if there will be any noticeable difference between a 'J'-pole mad of 10 - 12 gauge wire and one made form 'twin-lead', or one made from copper pipe. At least, not from the size of the conductors.
- 'Doc
joseph2020
CO. US
sorry about 2nd welcome above...It had to be the keyboard fault.
Ok, the "cheapo antenna project" is almost done...the latest 2 meter test results are in:
The rubber ducky that came with the radio shows about 3 bars. the telescoping antenna ( 20 inches) about 4 bars, the "ears" antenna about 6 bars, and the twin lead end fed J pole about 8+ bars and the only one where I could hear simplex about 30 miles away (no repeater)... we got a winner.
Getting a SWR will be the next step, but I'm guessing it is lower than critical or the radio would shut down. ]F anyone knows of a cheap used working SWR for sale for VHF please PM me. I sure wish I could get my hands on some of those old ham radio magazines (1940s - 1960s) when everyone just homebrewed all their equipment.
Thanks to all who replied to this topic. I am open to any further thoughts/ideas.
joseph2020
CO. US
I am famous thanks to the ears
I thought this was very funny. Try this, google or yahoo search for "rabbit ears for 2 meter" or just go here rabbit ears for 2 meter - Google Search Does that mean I am now famous? Or did I just show the extent of my ignorance internet wide? :lol:
lbfd09
California
Yep - you are not immortally embraced in Internet History.
Congrats. On both asking the question and helping all of us learn here.
majoco
Stirrer
New Zealand
Join your local radio club and after they find that your'e 'acceptable', somebody will give you an SWR meter! I have three kicking around here!
